587,349 active members*
2,964 visitors online*
Results 1 to 6 of 6
    Sep 2010
    17
    Fanuc 21i / DNC / Memory Cards
    Hi Folks
    I'm trying to introduce myself to cadcam systems and the large G code programs that can be generated. So I presume I need to know more about DNC drip feeding and/or memory expansion via PCMCIA/Flash card for a Fanuc 21i-MA.
    I think I have Program Memory B A02B-0247-H052 (SRAM B 512 kB) and I'm getting really confused with all these A and B suffixes!
    Regarding DNC: the manual talks of a 'Remote' switch on the operator panel. Can't find it (Machine is Chiron FZ08W). Can a parameter be changed instead?
    I'm also really confused with this M198 command: manual says "With a memory card RMT mode operation and the subprogram call function (based on the M198 command) cannot be used" I've also read somewhere of the programs from the card being loaded into cnc memory with M198P**** ..... so could anyone enlighten me here?
    I don't know if/how any of this is possible for this controller (or for a 21-MB or 0MD) but if yourselves could give a bit of a primer on the above it would be much appreciated.
    Regards
    Rob
    Jan 2006
    387
    I'm in the same boat with a 21MB. No card, so have to drip-feed from the RS232 port on the back of the machine. I ought to have something working by ... maybe the 20th, but I doubt it since everyone who can help me is at that trade show.
    I'm really familiar with async comm through serial ports on PC's, but the machine end is a total blank to me. Can we compare notes as we find solutions?
    2932
    Some machines have a "TAPE" mode, which will usually show up as RMT on the display. If your I/O device is set to 4 you should be able to drip-feed from a Compact Flash Card w/ a PCMCIA adapter.
    Using an older style SanDisk 256 or 512MB CF card is usually trouble free. You can get these from memorysuppliers.com for $19.95 or less. The newer high capacity cards may or may not work.
    http://www.memorysuppliers.com/san51comflas.html
    Does your 21iM have a card slot to the left of the display?
    Jan 2006
    387
    There's no card slot on my machine or controller, it dates from 1997. I have no idea how they loaded it before but as long as I can feed it infinite amounts of data through the RS-232 port I think I'll be ok. I realize that limits some of the features on the controller but I don't know how else to load a 3 meg file into 128k of RAM.
    I still have not seen it demonstrated. Until I do, I'll be in the dark.
    2932
    Quote Originally Posted by Ed_R View Post
    Are you able to send/receive through your RS232 port?
    Does your control have a TAPE mode?
    Jan 2006
    387
    Won't know any of that until the machine gets here. end of week at best.
  1. Fanuc OM-B Memory
    By Fine01 in forum Fanuc
    Last Post: 07-25-2018, 06:29 PM
  2. Fanuc 0m-b memory
    By systronic in forum Fanuc
    Last Post: 12-15-2008, 01:47 PM
  3. flash cards for fanuc controls
    By rags in forum Fanuc
    Last Post: 10-09-2008, 03:21 PM
  4. Fanuc 15m Memory
    By rugbyal in forum Fanuc
    Last Post: 03-04-2008, 01:15 AM
  5. Fanuc 0 M memory
    By matic in forum Fanuc
    Last Post: 05-27-2007, 06:33 PM
