587,517 active members*
2,721 visitors online*
Results 1 to 4 of 4
    Mar 2013
    0
    fanuc 210i-T sram problem
    Hi
    I have Colchester lathe with fanuc 210i-T, few days ago problems started occuring.
    When I am starting machine often only come blank screen and do not move or anything, but rarely
    when it boots up screen is all scrambled full of artefacts.
    I removed control and it has two rows of LED's and in one row red LED is ON beneath of it is written "sfail".
    This LED only glow red when machine do not boot up.
    I am sorry for bad english, I hope you can understand.
    Luka Bertone
ID:	180660Click image for larger version.
    Aug 2011
    2517
    that means SYS FAIL
    the Fanuc 210i maintenance manual says the motherboard or display control card may be faulty.
    so basically you have a major hardware failure.
    if that problem display was on a standard PC I'd immediately say the fan mounted on the video card has failed and the video card has cooked itself. so you may want to look at the video card first.
    Mar 2013
    0
    I will look into it, but this fanuc PC have passive cooling on processors and have two small vents that blows on the whole motherboard.
    Last few days it works, but there are vertical lines on screen.
    I thought that error is sram because man who services cnc machines told me that this LED means that.
    And paperwork of machine was lost so i canot look in manual (sarcastic smile).
    thank you for your time I will look into it.
    Apr 2009
    1379
    I strongly recommend a SRAM backup in BOOT mode when the control starts normally before you lose all data. That control does have a display module, which may be the problem.
  1. Fanuc SRAM card driver for windows XP
    By prasadmashal in forum Fanuc
    Last Post: 04-29-2014, 09:07 PM
  2. Replies: 4
    Last Post: 07-12-2012, 08:34 AM
  3. FANUC SRAM Memory Expansion
    By Aaron liang in forum Fanuc
    Last Post: 03-26-2012, 05:40 AM
  4. Need mainboard Fanuc 210i
    By jw46 in forum Want To Buy...Need help!
    Last Post: 04-05-2011, 08:37 PM
  5. Replies: 0
    Last Post: 07-22-2010, 02:03 PM
