587,404 active members*
3,244 visitors online*
Results 1 to 2 of 2
    Jan 2008
    1
    Fanuc 18i-T looses position when E-stop hit.
    We have an Okuma & Howa with a Fanuc 18i-T control. The guy working it hit the e-stop when a tool went west. He replaced the tool reset and ran the machine then......bang !! The machine had lost its position after the e-stop had been hit. This is fixed by powering the machine down and re-referencing. But the problem re-occurs every time the e-stop is hit.
    Is this a parameter enablement or a servo fault ???
    May 2003
    41
    Fanuc 18iT E-Stop Problem
    Dear Radish,
    Which axis looses position?
    Is it Gravity axis or any other axis?
    How much is the movement?
    Kindly clarify.
    smabhyan
  1. Fanuc 11M Absolute position probs
    By trotsky in forum Fanuc
    Last Post: 11-05-2007, 08:29 PM
  2. adjusting 2nd zero ref. position fanuc OM
    By harris-mach1 in forum Fanuc
    Last Post: 08-31-2007, 08:14 PM
  3. Fanuc 0M Reference Position
    By inthezone in forum Fanuc
    Last Post: 07-26-2007, 07:28 PM
  4. Home Position Fanuc OM-C
    By Derek.C in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-28-2007, 08:06 PM
  5. Position Display on fanuc 6m
    By fredf1 in forum Fanuc
    Last Post: 10-22-2005, 10:08 AM
