587,263 active members*
3,390 visitors online*
Results 1 to 11 of 11
    Jan 2017
    7
    FANUC 18i ERROR CODE 2025
    Hi guys i need help with Toshiba TUE-15 VTL fanuc 18i,. after not successful tool change actual tool number is 0, how to input manually a tool number in to parameter ? M06 does not work is coming up with this error 2025 - actual tool no 0 error. Any advice ? Thanks for any responses.
    May 2016
    526
    Re: FANUC 18i ERROR CODE 2025
    Whats in param 402,407,450 and 451
    Jan 2017
    7
    I do not have parameter 402,407,450,451 after 242 is jumping strait to 801. Any function must be on to get to this parameters ?
    Jan 2017
    7
    Any other advice ?
    Feb 2015
    161
    Quote Originally Posted by arturxyz View Post
    Are you looking at parameters?... or Diagnostics?
    Dec 2009
    968
    as far as i know the number of the tools are set in the D data---system-pmc---pmcprm----data----gdata somewhere from D450 or so.
    Jan 2017
    7
    I'am looking at the parameters and after 242 going strait to 801
    Jan 2017
    7
    The g-data have only 20 lines from no. 0001 to no. 0020, and number 0020 have address no. D0050 and that's it
    Dec 2009
    968
    copy the ladder and send it to me at [email protected] and i will look at it
    Jan 2017
    7
    Hi, sorry for long reply. How I can copy a ladder without memory card ? I only have connection to PC via RS 232 port.
    Quote Originally Posted by zavateandu View Post
    Jan 2017
    7
  1. FANUC Error Code HELP....
    By mckearnj in forum RFQ Feedback
    Last Post: 04-12-2011, 04:48 PM
  2. Need Help..Fanuc OMD-II error code: 420 & 421
    By Abdul Haq in forum Fanuc
    Last Post: 02-01-2010, 05:42 AM
  3. Fanuc Error code
    By Racecarengineer in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 06-12-2008, 06:46 PM
  4. Error code help on Fanuc
    By digger1969 in forum Fanuc
    Last Post: 03-29-2007, 10:38 AM
  5. Fanuc 21i-t error code
    By dinoflex in forum Fanuc
    Last Post: 08-18-2005, 10:01 PM
