587,651 active members*
3,564 visitors online*
Results 1 to 4 of 4
    Aug 2007
    2
    FANUC 16i Turn off B Axis
    Im working on a Kitamura horzontal maching center. I belive I have a bad cable from the B axis drive to the endcoder. The machine is in alarm. Dose anyone know what parameters to turn off to shut off the B axis and get this machine out of alarm. I need to move the Z axis forward to gain axcess to the B axis motor and endcoder conection.
    Mar 2007
    122
    4TH Axis parameters
    Parameter 1010 will be for your # of axises. Change to 3. I believe there are others you have to change but I don't have my list with me right now. I'll try to post them tomorrow or you could always call FANUC 1-888-FANUC-US (1888-326-8287) EXT 2.
    May 2006
    179
    Ours has a a 4th axis enable on the operators panel / alarm section. We just turn it off there
    Nov 2006
    175
    Parameter
    7 6 5 4 3 2 1 0
    012 RMVx
    Setting entry is acceptable.
    [Data type] Bit axis
    RMVx Releasing the alignment of the control axis for each axis
    0: Not released
    1: Released
    NOTE RMVx is valid when the bit7 (RMBx) in parameter 1005 is 1.
    7 6 5 4 3 2 1 0
    1005 RMBx MCCx
    RMBx Releasing the alignment of the control axis for each axis (signal input and setting input)
    0: Invalid
    1: Valid
    MCCx When an axis is released from control, control for the MCC signal for the corresponding servo amplifier is
    0: Disabled; 1: Enabled
  1. Fanuc OM-C 4th axis?
    By TR MFG in forum Fanuc
    Last Post: 09-04-2023, 12:14 PM
  2. Will X2 support mill /turn multi axis lathes?
    By bassn_07 in forum Mastercam
    Last Post: 04-27-2008, 12:58 AM
  3. mill/turn on a cin turn
    By Robert Timby in forum Uncategorised MetalWorking Machines
    Last Post: 02-01-2007, 05:33 AM
  4. Cin Turn turn/mill
    By Robert Timby in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-25-2007, 02:12 AM
  5. Ver 7.0 Eztrak 2 axis. Spindle wont turn
    By MrMudd in forum Bridgeport / Hardinge Mills
    Last Post: 06-13-2006, 07:18 PM
