Hi all,
I am trying to use my Dell laptop to download G-code programs to our 10M based vertical mill with no success, perhaps someone can point me in the right direction.
Setup: I made a 3 wire serial cable as per the pinout I found on the web. On my laptop I am running Hyperterminal 4800-1-E Xon/Xoff. I am assuming this arrangement is functional because when I "punch" all parameters from the 10M I see them scroll through on the hyperterminal window. The only weird thing is each line lacks a CR but has a LF, so the data walks diagonally across the screen, perhaps this indicates a setup issue...???
I resolved the "write protect" error; memory switch in protected position.
I added a program number to my file (O0000) and semi colons to each line(, now when I try to "transfer text file" it echos on the hyperterminal screen but does nothing on the 10M.
Oh forgot to mention the 10M setup, I put the control in EDIT mode, press the PROGRAM softkey, then READ, 1PRGM and finally NEW. Fanuc 10m indicates no program.
My program is just:
O0000;
G00X1.0Y1.0Z1.0;
Any thoughts would truly be appreciated because I certainly don't feel like keying in all my program lines!!!
Thanks,
Mike
