I have a Leadwell MCV 760 XL with a Fanuc 10M control. A while back, the machine had some problems and dumped the parameters. I was able to reload them and get the machine running again, however, the spindle only runs 2 speeds. the lower speed runs if it is programmed up to 1000 rpm, and the lower speed runs from 1001 and higher. The spindle runs full range of speeds in manual mode. I just changed the sensor under the fan on the spindle motor, and the motor sounds better, but only runs the 2 speeds.I It seems as though I am missing some type of parameters that govern spindle speeds.
Any help is appreciated
Thanks,
Mike
