587,781 active members*
2,874 visitors online*
Results 1 to 6 of 6
    Jun 2004
    26
    Fanuc 0M servo alarm question
    (EDIT) First off I just want to say thanks for this great forum... Very informative!
    Im having an issue with the drives throwing a.....
    401 SERVO ALARM (VRDY OFF)
    414 SERVO ALARM: X AXIS DETECT ERR
    424 SERVO ALARM: Y AXIS DETECT ERR
    434 SERVO ALARM: Z AXIS DETECT ERR
    444 SERVO ALARM: 4 AXIS DETECT ERR
    This seems to occur after about 5-10 minutes in random orders. Sometimes just the x and y or sometimes x and z or 3 at a time. It doesnt seem to be constant. The HC(High Current) LED being on is the only constant.
    Diagnostic..
    720-723
    00010000 on all Axis that show HC
    730 - 733
    All - 00000000
    Any input on what to look at next?
    May 2006
    82
    hi Geeserteg.
    I would be worry about alarm 401!
    This is what i have experienced in FANUC OT :
    Alarm 401 (velocity control ready signal was turned off)
    After few hours i track the 24vdc coming out from the Power Supply module,CX4 conector this line goes to several devices on the I/O board
    and finally i found that one of the contactor was not closing
    repair the cause (ground wire)
    And machine Works perfectly after that
    Hope that help!
    Jan 2007
    93
    Dear Geeserteg,
    This may be the result of sudden interrupted supply.
    Rajesh.
    Jun 2004
    26
    WOW these things are sensitive! I found the problem. It ended up being a coil on a relay going bad. It was pulling to much current.It just so happend that it was the one controlling the lubrication cycle hence the machine cutting out in about 10 minutes. Thanks guys!
    Jan 2016
    2
    Re: Fanuc 0M servo alarm question
    i have a supermax machine with fanuc o-m controller and it has a alarm of 434 z-axis detect error
    what should i do plz help me...............
    Feb 2015
    161
    Quote Originally Posted by goreyogesh View Post
    Please look at DGN 722. Which bit is on?
  1. Replies: 2
    Last Post: 09-10-2018, 09:21 PM
  2. Fanuc 6T Servo 400 Alarm
    By cic108 in forum Okuma
    Last Post: 07-07-2014, 02:08 PM
  3. Fanuc 6T-B alarm 402:servo Alarm
    By leiryll in forum Fanuc
    Last Post: 12-03-2013, 08:52 AM
  4. Replies: 0
    Last Post: 08-12-2013, 09:12 AM
  5. Fanuc 6M - 401 Servo Alarm
    By parametric.ms in forum Fanuc
    Last Post: 03-24-2010, 06:02 AM
