587,481 active members*
3,288 visitors online*
Results 1 to 9 of 9
    Feb 2021
    5
    FANUC 0M, HELP
    hi, I need help with a Fanuc Model-A (1988}. I can't find the right manual and I can't see the ladder program, it's not exhibit.
    I have tried to find the p0060 to edit it but it's not exhibited too, the parameters go until P0040 then direct to P0100. when I press the PRGRM button it's only the main program exhibited.
    sorry for my bad english, I'm very glad if someone can help me.
    thanks to all
    Enviado de meu Redmi Note 8 Pro usando o Tapatalk
    Oct 2009
    297
    Re: FANUC 0M, HELP
    Quote Originally Posted by gmega View Post
    thanks to all
    Ladder can be seen in FANUC control 0C. You cannot see it in 0A or 0B.
    Regards
    AlexFanuc
    Feb 2021
    5
    Re: FANUC 0M, HELP
    Quote Originally Posted by alexfanuc View Post
    Regards
    AlexFanuc
    hi Alex, thank you for the help.
    another question if you don't mind, I have a lathe here with 2 axes (X, Z). one of this axes, X in that case works fine for a few hours, about 6 or 7hrs and start to overheating, and alarm 410 X excess error appears. we have changed the drive, adjust the gains, changed the servos for repaired ones and the alarm keep occurring. any ideas of what I can do or measure to find what's causing this problem?
    the image is my diag screen with gains displayed.
    thank you!
    the servos are 0s A06B-0313-B033 both with 3000p encoder
    Oct 2009
    297
    Re: FANUC 0M, HELP
    thank you!
    Did you check the screwball? It seems like a mechanical problem.
    What kind of machine do you have?
    regards
    AlexFanuc
    Feb 2021
    5
    Re: FANUC 0M, HELP
    regards
    AlexFanuc
    I have a horizontal lathe, 2 axes. both axes, mechanically saying, are free. I think it's a problem with incorrect position of the encoder, there's any way to check that? any .pdf with instructions?
    Oct 2009
    297
    Re: FANUC 0M, HELP
    If you disengage the motor , will the problem appear?
    Regards
    AlexFanuc
    Feb 2021
    5
    Re: FANUC 0M, HELP
    Regards
    AlexFanuc
    yes, I have changed the motor between x and z and the problem keep occurring, even if I disengage from the axes.
    I have changed the servo for other one and him stoped overheating, I'll see if that's don't occurs anymore. thank you, Alex.
    Mar 2021
    12
    Re: FANUC 0M, HELP
    Pmc梯图是需要一个编辑卡插到主板上� �可以编辑了。如果没有编辑卡也可以� ��存储板上的两个芯片oe1与oe2拔下来用 读写器读出里面的文件,然后再勇编� �软件编辑合并后就可以用梯图软件打� ��了。打开修改后再把文件分拆成两个 文件,用读写器分别写到两个芯片里� �
    Mar 2021
    12
    Re: FANUC 0M, HELP
    X轴的报警,一般是机械负载过大,检� ��丝杠与轴承,轨道,润滑油吧
  1. Fanuc tape cut mate fanuc om paramter setting for cutting materials
    By Vijay040engg in forum EDM Discussion General Topics
    Last Post: 08-27-2019, 10:00 AM
  2. Replies: 5
    Last Post: 04-20-2019, 02:31 PM
  3. Replies: 12
    Last Post: 12-26-2016, 10:31 PM
  4. Replies: 8
    Last Post: 09-25-2014, 02:58 PM
