587,791 active members*
2,912 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc 0-TB Not ready, Ladder diagnostic
Results 1 to 7 of 7
    Mar 2013
    6
    Hello together...
    I have a Nakamura TW20.
    The left side of the machine is all time in "Not Ready".
    There is no Machine Alarm or something else.
    As far as I can read the Ladder, G0121.4 (ESP) should be 1, but is 0....
    Has anyone an idea?
    Greetings from Germany...
    Peter
    Jun 2004
    511
    Sounds like you are in Estop. That normaly is an hardwire problem, Limit switch or Estop button. The drives can cause this as well, check them for an error code.
    Dec 2003
    24220
    You need to trace back the ladder states that are showing the open status and see what the origin of them is.
    As mentioned, it could be the drive enables?
    Al.
    Albert E.
    Mar 2013
    6
    Hello...
    The Limit switch and Estop button are working, the signal comes clear in the PLC.
    Both Spindle amplifier (Left and right side - the right side of the machine is working, it is a separate control) show 0000 so i believe the amplifier are ok.
    The Servo drives have only a few LEDs but because the Machine is in Not Ready they will not got power...
    It is right that i add 2000 for the diagnostic parameters to check everything (like R955.2 => Parameter 2955.2)?
    X is input and Y is output, but what are D / R / F / G?
    Thanks for help...
    Peter
    Feb 2005
    8
    Nothing obvious except that G121.4 isn't on so you are in Estop.
    D is data table
    R is internal relay
    F is input signal from CNC to PMC
    G is output signal from PMC to CNC
    Are you sure the printout is correct for your machine? The TM2 looks like it was added. Other things may have been added too. Doesn't your control have ladder display? That makes it much easier to troubleshoot.
    Jerry
    Dec 2003
    24220
    IIRC, the ladder can only display on the 0C & 0D.
    On these you only have to set Par 60 bit #2.
    Al.
    Albert E.
    Jun 2007
    119
    What is x 8.5? is 0 and should be 1
    "It is right that i add 2000 for the diagnostic parameters to check everything (like R955.2 => Parameter 2955.2)?" NO
  1. fanuc 6t diagnostic 041 data bit 0
    By MITYDR in forum Fanuc
    Last Post: 01-19-2014, 01:49 AM
  2. Replies: 0
    Last Post: 11-11-2011, 04:32 PM
  3. Fanuc 0TB diagnostic output
    By guhl in forum Fanuc
    Last Post: 04-09-2009, 01:25 PM
  4. fanuc 0t pmc diagnostic parameters
    By machineryaxis in forum Fanuc
    Last Post: 03-22-2009, 07:49 AM
  5. Replies: 1
    Last Post: 09-20-2008, 12:40 PM
