I have a Colchester Tornado with Fanuc 0-T controller and want to back up all the parameters to pc. Can anyone help me out ?. I have no Fanuc manuals to give me a clue
Richard
Richard
See me a PM with email address. the pdf file is too big to post.
Al
Albert E.
We are currently head butting a Fanuc 0T with frustration... can I get a hold of that parameter list as well... It would be most appreciated.
Cheers.
Thanks Al that has worked a treat and i now have the parameters backed up
Can I also ask for Fanuc 0-T Parameters?
Put machine in edit mode
Press param page
press and hold EOB and press output start
Hello,
Can anyone help me with this issue?
I have an Star SST16 lathe with Fanuc O-TT and I don't know how to make the machine zero point reference procedure.
I really appreciate if someone can help me!
Attachment 405148
Attachment 405146
Thank you,
Valentin
Turn the dial to the datum sign then press x+ from recollection
I'm not sure what is datum sign...
What does parameter 22 say
