587,174 active members*
3,931 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc 0-MD Y axis reference is acting up
    Feb 2017
    3
    I am having a strange problem lately where my machine will home to a different position. The machine is an Eagle Yang SMV-1000 with a fanuc 0-MD controller.
    Every time I home the machine in manual, let's say to inspect a parts, the home postion on the Y axis will shift and controller absolute position gets reset with the new value. If I don't catch it the machine restart and the Y axis is shifted.
    I have gone thru the limit switch and even confirmed that the Home limit switch (X17.5) is working well and registering the dog at the same distance every time and it does.
    There is something in the reference return steps the machine is doing that I am not understanding. If I try to home the machine several time in a row it will get to a point where the data has shifted too much and after the deceleration it will overshoot and cause an overtravel alarm. I could use some advice!
    Feb 2017
    3
    Re: Fanuc 0-MD Y axis reference is acting up
    So a quick follow-up on my problem, it was indeed the home limit switch starting to act up. Playing with the Y axis in manual mode I was watching the X17.5 bit change and the behavior was erratic, a 30$ switch fixed it.
    Now I would just like to know if there is a parameter to turn off dog type reference return after the machine was homed on startup. When I program G28 Y0 the table will move in rapid to the home position but when I manually press the Y home buttons it will decelerate when reaching the home dog and basically do a new reference return that will reset machine absolute position if there is any difference.
    Mar 2024
    31
    Please discuss your problem with me at [email protected]
  1. Replies: 0
    Last Post: 05-19-2019, 09:06 AM
  2. Replies: 6
    Last Post: 03-17-2019, 02:57 PM
  3. Fanuc 6M-B 4th axis reference woes
    By PNaedele in forum Fanuc
    Last Post: 03-15-2018, 02:42 PM
  4. Fanuc OM acting up
    By Machinist3 in forum Fanuc
    Last Post: 02-24-2010, 02:34 AM
