Thanks for the reply. The SKIP input is actually working on this machine, so if I can modify the ladder, I should be able to use it.
Code:
N001 (move X +100 mm and then Y +100mm, if skip input is hit)
N003 G31 G1 F100. G90 X100.
N004 (If skip hit, position is in #5061 to #5064)
N005 Y100.
How do I modify the ladder of a machine that doesn't have a PMC card? Most of the FLADDER III documentation that I have seen lists compatibility with PMCs.
Thanks,
Eric
FYI - here's my machine setup
- Main Controller Board - A02B-0099-B544 (FS-0MD)
- Memory Card - A16B-2201-0101/09A
- I/O card - A16B-2203-0110/03A
- AXE (Axis Controller) card - A16B-2203-0020/01A (32-bit 0-C for serial pulse coder type B)
- No PMC
- No Graphics
