I am new to fagor 8055T. Is there any way to temporarily stop a part program execution then resume it later?
Yes, Before you restart the program, you have to find the block.
Pushing the red button puts it in halt mode, will resume on green button push.
If you mean a consistent stop in the middle of a program for tool check or measure or...... add the Gcode "M00"
www.integratedmechanical.ca
I want to open the door and clean the chip, but once I do so. the program ends and I must do block search stuff ....
yeah. I must do block search and find the block where the machine stopped. I am looking for pause - resume thing if there is any. Tq
What happens if you try a "tool check"?
- Pause program using red button
- press "T" (now you are in check mode and can even jog machine out of way if you want)
I pressed the red button
then " Tool Inspection"
but when I open the door to clean the chip, an error message pops up.
when I close the door and choose Esc or Main menu. in both cases if I press the start button , the program starts from beginning not from where it was.I s there a way to preserve the program stop point and resume it after cleaning the tool?
Hay all need your help.
Acer knee mill with Fagor control Model is a BED-1050 Acer. Not sure on the Model of the control yet.
Mach has Glentek SMA7110-04b-005A-1 drives. Getting AL 2001 X aixs feedback error.
If you have not figured it out by now. But if you press cycle hold then press the "t" key then you can jog and stop the spindle. Where your done jog the tool close to where it was when you stopped it and press cycle start and the screen will prompt you to get the program going again
