587,485 active members*
3,364 visitors online*
Thread: FADAL VMC 15
    Jan 2013
    16
    FADAL VMC 15
    The machine sat for almost a year. I MOVED the machine. I replaced the spindle motor. I ran the machine about 10 hours. It crashed (88 HS) mid-program. I re-started the machine. I got a "ERROR WHILE PROCESSING BLOCK ZERO" on the screen. I restarted the machine. It worked normal. It crashed mid-program again. I restarted. I get a 'green' screen with no wording. Could it be the backup battery or other connection? Could running with low air pressure do this? I don't have any of my programs backed up as I have never been able to communicate through the RS 232 port. Is there any way to extract the programs if the board is bad?
    My 2001 backup battery shows 3.58 volts.
    Jan 2004
    3154
    Re: FADAL VMC 15
    You may want to call a service tech
    www.integratedmechanical.ca
    Mar 2016
    40
    Re: FADAL VMC 15
    The CPU memory runs off of the cap when machine is on and if you power off it lasts for 2-3 days, then the battery takes over. I would try zeroing memory. Write down all SETP, SV, and BL values. Save all programs etc... Zeroing memory is in the diagnostics menu. Also check your high speed buss jumper card that plugs in the front of the CPU, video, comms card. Make sure there are no bent pins and it isfully seated.
  1. Replies: 3
    Last Post: 09-21-2014, 01:04 AM
  2. Looking for a Fadal....
    By alphaorange in forum Fadal
    Last Post: 07-23-2011, 11:40 PM
  3. Replies: 23
    Last Post: 11-17-2008, 10:28 PM
  4. Replies: 4
    Last Post: 03-02-2006, 04:46 AM
  5. Fadal EMC
    By YZ426Tony in forum Fadal
    Last Post: 12-13-2005, 08:01 PM
