587,349 active members*
3,001 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Fadal Enclosure Top Cover
Results 1 to 7 of 7
    Oct 2008
    1639
    So, I have a sheet metal shop and I also have a newly acquired Fadal.
    Does anyone have any pictures of the top covers for the enclosure so I might be able to clone?
    I'm sure it can't be too difficult but hey, why reinvent it.
    I hear/see mention of some guy on ebay but nothing came up for me.
    Also, why buy if I can build!
    Richard
    Jan 2015
    417
    Re: Fadal Enclosure Top Cover
    this is a 4020 but page 32 https://itscnc.com/images/VMC_4020.pdf you can download any machine from here for part numbers and drawings here is the 3016 https://itscnc.com/images/VMC_3016.pdf
    Oct 2008
    1639
    Thanks. I have the parts book. I was more less talking about the aftermarket covers that people make to keep chips and coolant from flying out the top of the enclosure.
    I've seen several folks asking about them so I was curious more than anything else.
    Here is a DXF of one I made for my 4020
    Oct 2008
    1639
    JBRanting, thanks for the file!
    From hours and hours scrubbing all the nasty stuff under the enclosure I have to assume it leaks like crazy at every joint and the top may be the least of my worries!
    It honestly amazes me that anyone would design an enclosure like this. Typically, the bottom pan would have a nice lip pointed up and all the walls would go on the inside of that lip. At least that is how I designed my previous enclosures and they sure didn't need caulk nor did they leak. I also noticed everything pools at the front of the enclosure because it doesn't tilt back towards the drains.
    I hadn't made up my mind if I'm removing panels, cleaning, and resealing or if I plan to clean up the edges and use a good lap sealant. What is in there now looks like bathroom caulking and isn't holding up very well.
    Nov 2003
    287
    I used polyurethane caulk that seems to hold up well.
    Oct 2008
    1639
    I'm thinking, or hoping, I can just pull the bolts out of the bottom pans and drop each one individually and leave the side panels where they are,
    so I can clean and reapply sealant around the parameter, replace the pan then move to the next one.
    It doesn't look like very many bolts. Oh, and I have bonded sealing washers for all the bolts so that should help some as well.
    Richard
  1. Fadal VMC 40 Way Cover Wiper Part Number
    By NismoGT in forum Fadal
    Last Post: 05-28-2019, 07:22 PM
  2. Fadal 4020 Cover
    By rileydcasey in forum Fadal
    Last Post: 02-27-2018, 08:48 PM
  3. Fadal Stainless cover needed
    By proMachine in forum Fadal
    Last Post: 03-03-2017, 07:44 PM
  4. Fadal VMC40 Y Axis way cover removal
    By JamesJr in forum Fadal
    Last Post: 06-27-2013, 08:10 PM
  5. Box Way Cover- Fadal Wipers for VMC15
    By scadvice in forum Fadal
    Last Post: 06-20-2009, 04:59 PM
