I am using Flash CPR for rendering the toolpath. How do I make a facet body from there so I can use that for rest machining?
Thank You
Thank You
Right click on the render control palette and towards the bottom of the options menu you will have two choices: Save to STL & Create Facet Body.
Looks like you have standard CPR enabled. With CPR off, right click on the CPR Tile and select Flash CPR. when Flash CPR is selected you can change your view without CPR starting over and your right click menu will display the 2 STL creation options cadman listed along with other things like transparent stock
Yeah, it solved my problem, thank you very much ! Much appreciated!
