I have searched EzTrak on the forum and read a lot, but still can't find exactly what I think I need. I am working on an EzTrak DX that has been previously tinkered with by a computer repairman. It has a new motherboard and hard drive. The owner of the machine has gotten DOS 6.xx boot and EzTrak 3.5"s. On initial startup, after loading the EzTrak files, this message is displayed, "Insert Old System Disk To Transfer Sys Parameters". Since I do not have that disk I hit "Enter" and "SYS.BEZ not found, loading old Parameters" will be displayed. Then the BMDC counts down to "0", not loading, and the display will then say "Set Parameter (1) Failed. Error Setting Parameter 1". If I hit any key the system error - possible pointer error message is displayed.
What do I need to do? Do I need to reset the parameters? Help.
Thanks in advance.
