586,035 active members*
3,712 visitors online*
Results 1 to 2 of 2
    Apr 2014
    14
    Unhappy EZpath lathe Alarm Power/off manual
    Our Bridgeport EZ Path lathe is giving an alarm. Alarm power/Off manual... hit any key. When I hit any key it switches to Alarm Emergency Stop Activated.... Hit any key. When I hit any key it does not clear. Not sure where to start any help would be great.
    Thank you, Ed
    Apr 2014
    14
    Re: EZpath lathe Alarm Power/off manual
    All set. Not sure what I did to fix it tho. I reset with red button on front . had same alarm. then I pushed and pulled both emergency stops one at a time. Then moved the spindle control handle forward and back. Pressed 0 and it went to the usual start up screen. I don't know maybe a stuck emergency stop button. I had cycled thru all the above several times before with no success,maybe not in the same order. Well love this site we'll see if she stays running. Post was not up long before fix so no replies but I'm sure there would have been.
    Great site ,Great community thank you,
    Ed
  1. Clausing Colchester manual lathe conversion to CNC (keep manual also)
    By 86turbodsl in forum Uncategorised MetalWorking Machines
    Last Post: 11-10-2014, 01:50 PM
  2. #10 Internal Addressing Error on Bridgeport EZPath Lathe
    By fijinx in forum Bridgeport / Hardinge Mills
    Last Post: 08-23-2013, 01:16 AM
  3. Replies: 6
    Last Post: 03-13-2013, 03:32 PM
  4. manual lathe convert cnc/manual lathe
    By kakayo in forum Vertical Mill, Lathe Project Log
    Last Post: 02-21-2010, 08:13 PM
  5. Bridgeport EZpath lathe
    By camtd in forum Uncategorised MetalWorking Machines
    Last Post: 02-16-2009, 09:55 PM
