587,472 active members*
2,980 visitors online*
Results 1 to 5 of 5
    Mar 2008
    51
    Extend a line
    Hello all,
    On the attached drawing I used the Line Parallel command to draw the red lines offset .250" from the inner blue lines and was wondering if there is a way to extend the red lines so they join.
    Ed.
    Jun 2008
    1838
    Quote Originally Posted by emd68 View Post
    Hello all,
    Ed.
    Go to "Utilities > Trim Extend > Screen
    Click on a line say the top one and then move the cursor some way to the right past where you want to join the lines and left click and the line will be extended, then do the same with the vertical line and take it past the extended horizontal one you just created, carry on and do the same routine with all the lines, the lines will now all be crossing each other, now go to :-
    "Utilities > Trim Extend > Quick Trim
    Now you can just click on the part of the line that is past the join point and it will be trimmed off.
    Sounds a lot but is really quite quick and easy once you`ve done it a couple of times
    Regards
    Feb 2010
    71
    Hi Ed,
    Try "trim two entities".
    doug
    Mar 2008
    51
    Thanks guys I tried both methods, both worked great but the Trim Two Entities is the way to go much faster.
    Thanks again
    Ed.
    Apr 2009
    3376
    Like everything,many ways to be done.I can thing of quite a few,here's one more,however a little more "clicks"Point Intersect,then Line Join.But then you have to delete point and Re-Organize to get single entities.
  1. how to extend 4x4 plasmacam
    By hardsteel in forum PlasmaCam
    Last Post: 02-28-2013, 04:16 AM
  2. Replies: 7
    Last Post: 10-17-2011, 05:27 AM
  3. Extend width of TM1/TM2 by 1ft
    By schoobie in forum Torchmate
    Last Post: 07-17-2008, 09:07 PM
  4. Extend a line (Design)
    By jorgehrr in forum Mastercam
    Last Post: 05-02-2007, 08:29 PM
  5. Trim and extend?
    By tinman13 in forum BobCad-Cam
    Last Post: 03-30-2006, 05:11 PM
