Has any body figured out how to rejoin a spline after exploding ?
Some programs have join polyline but I can not find anything in Bobcad that will do it. Am I missing something?
RAF
RAF
Only for tool paths,then use contours
You can use Fit Arcs to reduce the number of entities.
That's all I got.
Thanks jrmach
Yes the contours don't do much on the drawing side its kind of a down fall in Bob cad I guess.
never mind,thought there was something in 27 to help,,but I think not
maybe in the next update.....shouldnt have to wait till next version...i wouldnt think
Big Chipin, spreading tha cheese, I be Big Chipin for days!
Didn't you give the answer here yesterday?
The command is "spline approximated"....
The method is to select the exploded/segmented entities, then run and exit the command.....
Actually, all the spline tools do this now.. So you can rebuild your entities with interpolated or fitted also!!!
Yes,Yes I did,,,BUT,,I went back to prove it and I could not do it so I thought I was full of it,lol
Can we have a Video Burr,ha
Well, here's a brief one:
rebuild bob - YouTube
Thanks,man that is different,,,no right click or space bar or click here.................Highlight,then run the command,hmmmmm
RAF,did you get it ?
