587,434 active members*
3,161 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Excel PMC 5T18, Fanuck 21:Tool Change Sticks
Results 1 to 6 of 6
    Nov 2011
    0
    Excel mill has swing arm that changes tools. When it grabs the tool in the spindle, it hangs for a second and then drops down with the tool and continues the change cycle. Sometimes, after it pulls the tpol and drops down it rotates toward home but quits half way. Have to manually push the relays inside the machine to complete the cycle.
    However, It works perfectly with no tool in the spindle. There doesn't seem to be anything wrong mechanically.
    The signal to the relay that controls the rotation of the arm drops before the arm completes its cycle. Manually activating the relay completes the cycle.
    Any help to fix this problem or where to look to further diagnose will be appreciated.
    Sep 2010
    1230
    It may be the relay itself that's causing the problem. Recently, a situation with a clients machine, where the bar feeder would either randomly not feed, or multiple feed, the cause of which was traced to a faulty relay.
    In position of the components of a tool changer is generally monitored by proximity switches. I would find the addresses of all proximity switches associated with the troublesome part of the tool change, and monitor theirs state via the diagnostic page. Watch to see if their is a change of state that is causing the relay to swich prior to the arm reaching its correct position.
    If you're unsure of logic involved with the tool change routine, find that area in the Ladder, either hard copy, or via the control, to get a better understanding of how the various I/O interact.
    Regards,
    Bill
    Nov 2011
    0
    Tool Change sticks
    When it hangs half way it isn't near the proximity switch. When it runs properly (without a tool holder in the spindle) it stops at the proper place.
    I'll try to get a relay and replace the one that may be bad.
    Nov 2011
    0
    Contactor cross reference needed
    The contactor according to the book is FUJI SW-03RM/3H, the part is marked SC-03(11).
    The relay is Fuji HH52 PL.
    I'm looking for cross reference to other manufacturers or an updated part number.
    :cheers:
    Mar 2005
    816
    I've bought Fuji stuff from AutomationDirect. They can be a bit pricey on some stuff but generally most stuff is good.
    Otherwise Fuji is:
    FUJI ELECTRIC FA COMPONENTS & SYSTEMS
    You can look at this for the HH52, etc.
    http://www.fujielectric.co.jp/fcs/en...a_P025_036.pdf
    http://www.fujielectric.co.jp/fcs/en...pdf/AEH561.pdf
    fuji eletric has tons of catalogs and reference information and other stuff for relays, contactors online..
    anything beginning with S in their part numbers seem to be the japanese part number.
    Jul 2011
    21
    Hi, se have lost the parameters of our machine. Could you help us with a copy of your machine parameters?
    Best regards
    Quote Originally Posted by capngene View Post
  1. Tool Holder sticks in Spindle
    By bushmaster556 in forum Haas Lathes
    Last Post: 04-27-2021, 06:26 PM
  2. Replies: 19
    Last Post: 11-07-2019, 08:16 PM
  3. Haas spindle sticks during tool change
    By tjamscad in forum Haas Mills
    Last Post: 09-16-2013, 11:46 PM
  4. Replies: 4
    Last Post: 09-08-2008, 03:50 PM
  5. excel machining center - tool change issues
    By CVTE66 in forum CNC Machining Centers
    Last Post: 11-19-2007, 01:27 PM
