587,699 active members*
3,686 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Error checking in NCFadal
Results 1 to 10 of 10
    Dec 2003
    180
    I get a ton of error messages when trying to DNC using NCFadal. I can't pin it down. Some files work fine, others error out.
    If I un-check error checking at the CNC end. Things run fine.
    Any input would be appreciated.
    Dec 2003
    180
    Update: things don't work fine. I'm getting errors that stop the machine randomly. On the last test file, NCFadal quit mid file.
    I'm scratching my head as to where to look first. NCFadal, VisualMill post?
    900
    When using the NC Fadal software for DNC, DO NOT check the error checking option as this is too sensitive and picks up minor clitches that mean nothing. Unless you have an absolute need for the error checking leave it off!!!!!
    Neal
    Dec 2003
    180
    Thanks Neal. That makes a huge difference.
    Still crapping out on arcs. Is there a trick or do I just need to post all arcs as line segments?
    Jan 2004
    3154
    Do you feel for sure that it is an issue with code?
    Usually, seems to be com issues for this kind of behavior.
    Such as using Usb - serial devices.
    I have never had 1 problem since I switched to a proper serial card.
    www.integratedmechanical.ca
    Dec 2003
    180
    I'm pretty sure we're using a serial card but I'll double check. Culd the problem be in the post? It's set for radius arcs.
    900
    It maybe that the CA/CAM system is not properly connecting the arcs. If the control see a mismatch over .0001 or .0002 it may reject it. If this is the case set your CAD to the lowest tolerance available. The resulting file will be larger but will not execute any slower.
    Neal
    Jan 2004
    3154
    IDK about radius programming. I have always used IJK programming on my 88HS in format 2
    May 2004
    4519
    Are you sure you are not having connectivity issues with the cable due to vibration during operation?
    Dec 2003
    180
    Quote Originally Posted by txcncman View Post
    I won't rule it out but we were doing mostly aircuts or practice cuts on wood so about as little vibration as you can get.
  1. Looking for NC checking software...
    By Jesusbot in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 06-04-2012, 04:01 AM
  2. NCFadal v1.3 - 95 4020 88HS question
    By Wade C in forum Fadal
    Last Post: 11-04-2010, 03:14 AM
  3. Checking following error 8025
    By Captdave in forum Fagor Automation
    Last Post: 12-06-2009, 10:33 PM
  4. CHECKING
    By CHANDRU in forum Fanuc
    Last Post: 12-25-2007, 02:48 AM
  5. Ncfadal on xp
    By dango in forum Fadal
    Last Post: 02-11-2007, 05:46 PM
