587,925 active members*
3,895 visitors online*
Results 1 to 2 of 2
    Aug 2018
    14
    error 403, 444 and HCAL
    Dear all,
    I have a CNC punch machine: Murata Weideman Magnum 5000 with Fanuc control series 0
    I am in a trouble follow as:
    When i press "Zero Set", after X,Y,T axis go home then C axis go home so on the screen, the error immediately occur: 403 Servo (VRDY OFF) and 444: C servo dection ERR.
    In the DGN 723 for 4th axis (= C axis) bit 4 =1 is mean: HCAL alarm.
    I checked cable, driver, reaplce motor so seemingly every thing is okay.
    And i want to know the reason why when power on, with C axis, i can rorate it by hand while i can't do it with X,Y,T . Is there a parameter or signal effect "Servo ON" of C axis?
    Thanks for your reading.
    Noziz
    Sep 2010
    125
    Quote Originally Posted by noziz View Post
    Dear all,
    Noziz
    Your servo drive (A06B-6058-H###)is dead , short circuit transistor module or ccurrent loop on control pcb
  1. Replies: 8
    Last Post: 02-06-2015, 03:56 PM
  2. sl-1, fanuc 6t, 401 servo alarm, hcal
    By Johnboy13 in forum Mori Seiki lathes
    Last Post: 03-08-2014, 05:01 PM
  3. Replies: 0
    Last Post: 05-05-2013, 05:40 AM
  4. Yaskawa Servopack error: A.D1. Motor Load Position Excess Error
    By Syphonics in forum Servo Motors / Drives
    Last Post: 04-26-2012, 07:53 AM
  5. HCAL, Servo 401 Fanuc 6mb
    By Andy Fritz in forum Fanuc
    Last Post: 01-20-2010, 01:06 PM
