587,571 active members*
3,768 visitors online*
IndustryArena Forum > Other Machines > Machine Created Art > engraving with mastercam.
    Jan 2004
    258
    I have mastercam 9. I knew a guy a few years ago that used to scan in peoples written names and engrave them using mastercam. I have an 1800's flat document that I need to engrave into a project that I am working on. How can I do this?
    Dec 2008
    3128
    You would get better responses in the mastercam section
    But,
    in V9, you have to be able to get lines and arcs ( some say vectors ) onto the screen ( you may need odditional software- not sure )
    You then select these entities, define a tool ( taper is the normal selected tool, but it is your choice ) and to make the tool follow them , cutter compensation is OFF, you select the top of stock and the depth settings and you're off and going
    PS. I forgot to add that "lead in / outs" turned OFF, and XY offset to zero
    Sep 2008
    111
    You can use Inkscape (free) to open the image, the I forget where or who, but if you search for a dxf add-in for inkscape there is one that works very well. then you can improt a dxf into mastercam.
  1. MASTERCAM OR NOT TO MASTERCAM. THAT IS THE QUESTION.
    By Jonathan E. in forum Mastercam
    Last Post: 03-06-2016, 08:33 PM
  2. nesting mastercam x or mastercam x3
    By zewanil in forum Mastercam
    Last Post: 05-21-2009, 07:30 PM
  3. OD engraving?
    By bassn_07 in forum Esprit
    Last Post: 05-11-2008, 06:30 AM
  4. text engraving in Mastercam...
    By gearsoup in forum Mastercam
    Last Post: 05-29-2007, 03:12 PM
  5. engraving
    By dickiedog in forum Community Club House
    Last Post: 12-24-2006, 11:00 PM
