I would like some help on what tools I should use for engraving. I have a small CNC mill which can run at 3600RPM. I use the RhinoCam software to create the toolpaths/G-code. For engraving text, what would you recommend for engraving bits? I have tried using dremel bits with a ball nose but I either break them or the text is sloppy. My engraving is always done on a flat surface so nothing fancy.
I generally use 6160 aluminum but will be doing some mild carbon steel too? If you have help, please let me know.
