Originally Posted by
benji2505
We have the spring loaded engraver. Depth of engraving is controlled by feedrate, rpm and the spring. The piece works well if you want to engrave on surfaces that are not totally flat, it keeps the depth of engraving (and therefore the line width) constant. Engraving on round surfaces does not work if you get too far off center, it shows in the engraving itself. I'd say 15 degrees between table and the surface is the max.
Engraving anodized Aluminum will give you feedrates of 10-15 ipm and if you want to engrave longer texts/signs/drawings it will be time consuming.
We use it for machine front and back plates where we have a hard time mounting it down flat. If we have a flat surface we only use the engraving mill in a regular TTS holder.
The software that comes with the package is more or less useless to us. The number of fonts is rather limited and the import of dxf files has always caused problem for us. We de-installed it after a short period of time and went with the solutions in our CAM program(s).
Hope that helps.
benji
