587,409 active members*
3,433 visitors online*
IndustryArena Forum > MetalWorking Machines > EMCO CNC Machines > EMCO Lathe > Emco compact 5 pc lathe - linuxcnc setup without circuit board hack.
Page 4 of 4 234
Results 61 to 71 of 71
  1. #61
    Re: Emco compact 5 pc lathe - linuxcnc setup without circuit board hack.
    I was running my lathe tonite and remembered I said I'd post a vid (it's been a while) It's a bit fuzzy because my phone has a mind of it's own . For as simple of a part that it is , it's been tough to get it tuned in . I still have a few tweaks to do on the program .
    The large diameter at .3125 is the critical which I try to keep within a few tenths , the smaller diameter is .19 and a clean finish is the only real critical on that portion .
    I like to use carbides but they can be fussy on .375 dia stock with a 2.25 stick out . I've ground a hss blank and it's cutting nice . The deflection is quite noticeable in the video but the spring passes leave me with a nice finish and consistent sizes between parts
    You sharing your info here is highly appreciated , I've made a lot of parts on this little machine . The only upgrade that I've done is the recently added tool turret . The turret is connected to an arduino controlling a pc power supply and relays , and I use a push button to index
    This little lathe runs great with the linuxcnc . The only problem that I face right now is that I've somehow lost a chunk out of my encoder disc and my rpm's are a bit wacky on the control . It doesn't have any ill effect on regular turning but I think I'm going to have trouble with threading . I'm always watching ebay , so I'm sure one will pop up on there sooner or later , thats how I found this to begin with . Either way , this little toy rocks
    https://youtu.be/umkHsZmGXMM Attachment 454724
    A poet knows no boundary yet he is bound to the boundaries of ones own mind !! ........
  2. #62
    Jul 2003
    1754
    Awesome! How the heck did you lose a chunk from the encoder wheel? All of mine are stamped tin.. ( actually - I could send you one....)
  3. #63
    May 2015
    686
    Man, I wish I could find a machine like this downunder! There is one available at AUD $2.5k with no turret and its interstate so shipping would be a bit but I think he's asking too much. What do you guys think?
    Rod Webster
    www.vehiclemods.net.au
  4. #64
    Sam If you have a spare to send then ya let me know your price
    I have no idea of how I did that damage . mine looks to be stamped to and I'd expect it to bend if anything . It broke at the top portion of around 1/2 dozen holes , so I'm thinking a bit of metal epoxy putty could possibly be formed to replace that chunk .
    I had the lathe tipped up at one point to get at the gibs to tighten them and the lathe took a bad spill , so I'm expecting something must have wacked it at that point but who knows . Aside from that this thing is very consistent when I do batches of parts . Like any lathe the sizes will creep until the bearings are fully warmed up and after that I can keep pumping out parts .
    I can take a pretty heavy cut considering how little of casting there is to the lathe . The only cuts that really get the vibrations up are a straight in .125 wide groove cut , and that doesn't come as a surprise . Yesterday scared me , I was taking heavy groove cuts and suddenly the vibration went nuts . I stopped it and I could move the chuck side to side . First thing that immediately came to mind was I blew the bearing . Turned out the vibration was heavy enough to rattle the bolts loose on the chuck mounting plate , I was relieved lol . The chuck and that plate were a replacement for the original chuck and I mustn't have had the plate tightened enough from the get go
    Rod
    If the lathe is in good shape and ready to go then I honestly don't see a problem with the price if it can be justified with enough parts . From what I've been able to track online about these things , it seems they were awful expense out of the factory , but they mostly targeted schools who had big budgets . If a guy weighs out a retrofit vs a pre-built then time and cost is always a factor . I found this one on ebay for 1200us plus a couple hundred to ship . A new chuck and mount plate were around a couple hundred and the turret was just over 500
    It was a good deal because I haven't seen another come up any where near the same price , and they are usually $2500+ when they do come up
  5. #65
    I forgot to mention something with the manual push button controlled turret . It will be easy to mount a switch on the lathe , and add into the program to tap the switch with the carriage to to do a tool change . It may take a tap with a dwell or a few to index to the proper tool , but it will be simple and is in the plans for the near future . Or wire it in on a relay
  6. #66
    Jul 2003
    1754
    Pm me your address.
  7. #67
    right on dude will do
  8. #68
    May 2022
    3
    Hi, I'm trying to get the little emco pc lathe up and going and got an error about the port address being wrong and the axes being outdated code. I found the word axes in the ini file and it appears it may be a mistype of axis, is that a good guess or am I off the track ? Would it be a good idea to change the line " loadrt hal_parport cfg="0x378 out " " to read " loadrt hal_parport cfg="0 out " and let the system sort it or is my grasp of the code way off ? It's been more than 20 years since I did any coding. Thanx.
  9. #69
    Are you running straight from a parallel port or through a mesa card ?
    If your running through a pp then you should be able to drop the files in the configs and run from there . I'm using the download files - latest / full step and they work great .
  10. #70
    May 2022
    3
    Quote Originally Posted by metalmayhem View Post
    Hi metal, I am trying to do it through a parallel port, the machine starts up and the steppers lock up so I'm assuming everything is fine on the machine. I had to do a ton of cleaning and resetting the guides but all smooth with minimal ware shows up now.
    I have read some more info and have now reloaded the computer with debian wheezy preempt 3.4.55-4 and the getting started guide says I have to install a new kernel so I will go through the guide provided before I try to run the full step and half step folders again.
    I will post again of the results unless you have some better advice on which distro to use. Thanx for the reply.
  11. #71
    May 2022
    3
    All sorted, linux didn't like the parallel port card now to digest the jargon and learn gcode and one of the cad cam progs.
  12. #72
    HI do u know where i can find the dongle of Emco COmpact 5pc?
Page 4 of 4 234
  1. emco compact 5 lathe
    By phil t in forum EMCO Lathe
    Last Post: 02-19-2011, 05:32 AM
  2. EMCO compact 5 cnc lathe
    By MJC67 in forum Benchtop Machines
    Last Post: 07-17-2010, 05:37 PM
  3. WTB: EMCO Compact 5 CNC CPU board
    By dfstrasser in forum Want To Buy...Need help!
    Last Post: 04-16-2009, 10:20 AM
  4. EMCO Compact 5 CNC CPU board needed.
    By dfstrasser in forum Mini Lathe
    Last Post: 09-18-2008, 04:01 AM
