Strait from the emc2 mailing list. (thanks to all the developers for all their hard work)
As most of you probably know, the latest version of Ubuntu has been released
a couple weeks ago: Ubuntu 8.04 Hardy Heron.
(http://www.ubuntu.com/news/ubuntu-8.04-lts-desktop)
As it is another LTS release (3 year support on the Desktop version - which
we use), we consider that it's important to have emc2 packages (along with
the needed infrastructure: patched kernel, rtai, etc) for it.
Consiquently we have built packages, a repository for them, and a LiveCD for
easy testing and install.
(this procedure took a longer period of time, until the packages/LiveCD were
free of issues, and I would like to thank all testers that helped during
this tedious process).
== note ==
Before describing download and install procedures I would like to point out
that at this point the packages have been tested by a large number of
people, and only a couple problems have been reported so far (on some
hardware where it doesn't work at all).
However I do not encourage at this point to replace a working dapper install
with the new hardy version, unless there is really good reason to do so.
Ubuntu 6.06 Dapper Drake is still supported until 2009, and as long as it's
supported we will be building emc2 packages for it.
The cases where you should chose Hardy over Dapper are:
* new hardware that doesn't work on dapper
* you're doing a brand new install
* you _really_ want to be on the bleeding edge (not encouraged)
== Installing/testing procedures: ==
1. starting with a LiveCD (provides means for testing only, or even install
if wanted)
Step 1: Download the iso from:
http://www.linuxcnc.org/hardy/ubuntu...-aj07-i386.iso
(note: this URL might change in the future, reference
http://www.linuxcnc.org/ for the latest download link, and for a description
of known problems).
Step 2: Check the MD5SUM (note: also mentioned at http://www.linuxcnc.org/,
the latest one is: 91c5abb84386091e0ff056e9ebc40fdb)
Step 3: burn the image
Step 4: boot it on your PC (Note: the Hardy Heron LiveCD needs at least
384MB RAM to boot in Live mode, or 256MB for installing, an existing swap
partition on the harddrive will be picked up, so it might be possible to
boot the Live version on systems with less memory).
If you're happy with how it works/looks, install it on your machine.
Step 5: report problems (&successes) encountered
2. starting with an existing Ubuntu 8.04 Hardy Heron install
Step 1: Install Ubuntu 8.04
Step 2: Once you have installed Ubuntu , get the install script from here:
http://www.linuxcnc.org/hardy/emc2-install.sh , choose "Save to Disk" and
click OK.
Step 3: Now an emc2-install.sh icon will appear on your Desktop. Right-click
that icon, select Properties. Go to the Permissions tab and check the box
for Owner: Execute. Close the Properties window.
Step 4: Now double-click the emc2-install.sh icon, and select "Run in
Terminal". A terminal will appear and you will be asked for your password.
Step 5: When the installation asks if you are sure you want to install the
EMC2 packages, hit Enter to accept. Now just allow the install to finish.
Step 6: When it is done, you must reboot (System > Log Out > Restart the
Computer) - once you have rebooted you can run EMC2 by selecting it on the
Applications > CNC menu.
Step 7: If you aren't ready to set up a machine configuration, try the
sim-AXIS configuration; it runs a "simulated machine" that requires no
attached hardware.
Step 8: If you experience problems with things that used to work on the
default hardy, but don't after installing emc2, chances are you need one of
the special modules. (you can install them with: sudo apt-get install
linux-ubuntu-modules-hardy-rtai).
== Reporting problems & getting help ==
Reporting issues/problems/nags/ideas for improvements or anything else, can
be done via email (on this list, or directly to me), via IRC (#emc-devel on
irc.freenode.net) or via bug-reports at
http://sourceforge.net/tracker/?grou...44&atid=106744
Thanks for your patience, and for all the help to make it another great
release.
Best regards,
Alex Joni
