Does anyone know if the default config should work with The HobbyCNC board?
Hobby CNC has:
Outputs
Pin 2 - X axis Direction
Pin 3 - X axis step
Pin 4 - Y axis Direction
Pin 5 - Y axis step
Pin 6 - Z axis Direction
Pin 7 - Z axis step
Pin 8 - A axis Direction *
Pin 9 - A axis step *
Other output pins: Suggested/optional uses
Pins 10-13,15 have pullup resistors
Pin 10 - Limit (NC switches in series)
Pin 11 - Home X (NC or NO switch as desired)
Pin 12 - Home Y (NC or NO switch as desired)
Pin 13 - Home Z (NC or NO switch as desired)
Pin 15 - Home A (NC or NO switch as desired) *
Pin 14,16,17 have no pullup resistors
Pin 14 - Not assigned - Router/Spindel on/off **
Pin 16 - Not assigned
Pin 17 - Not assigned
Pin 1 - Not brought out for use on the board. A small 'hack' could make it available.
* - Many do not have/use this axis - typically used in heated bow CNC cutters for styrafoam
** - My desired use
