587,684 active members*
3,221 visitors online*
IndustryArena Forum > CNC Plasma, EDM / Waterjet Machines > EDM Discussion General Topics > Elox Fanuc Q series shutting down on start up
Results 1 to 8 of 8
    Apr 2010
    0
    Hello,
    We have an Elox Fanuc Q series that keeps shutting down on start up. Thinking it might be a ground fault but having trouble finding anything. Does anybody have any ideas?? Also, does anyone know of where to aquire a wiring diagram/schematic for this machine?
    Thanks.
    Aug 2008
    406
    I have a O Doing the same thing , have you checked all the fuses ? Check the 24 volt power supplies . On my machine its the input power unit . What is the master board number........?
    Apr 2010
    0
    all fuses are ok, so is the power supply. the board # is C5Q0305.
    thanks for the reply.
    Apr 2010
    0
    Quote Originally Posted by T-Lang View Post
    I might add one small thing that could save you much heart ache:
    ..................."Drag it outside (on skates!) and burn it"!!!!!!!!!!!!
    Oh, & tell the old man that he owes me a wee drink........or 6!
    :cheers:
    PAul
    Apr 2010
    0
    ha!
    i'd like to test your theory but i'm almost certain that a turd can't be set on fire.
    as for the drinks, next time i'm up we'll have to work away on 24 of the tasty little buggers.
    Aug 2005
    48
    For a Fanuc to go into cycle. And lock. You must have 4 things.
    Wire
    Water
    Tension
    Power
    Have you checked the wire break switch or switches?
    Apr 2010
    0
    FIXED!
    Jim,
    We isolated the failed item on the power supply & replaced it with a "similar" Fanuc part!
    We got lucky.........working fine now.
    Paul
    Aug 2005
    48
    Good deal...
    Don't be to tuff on the old Fanuc machines.
    I just did a service call on a 1985 model that had never had the doors unlocked for a problem of any kind. They had changed out normal wear parts and expendables. But not one service call!
    I have an "R" model in a plant (and many more like it of different models) that has been running 24/7 since 1986. They put a new other brand next to it in 1990 it was shot by 1999 so they bought another different brand to replace it. It is now pretty worn out and they are looking at having to replace it again. The Fanuc is still cutting parts. It still holds tolerance and is a lot ezer to maintain than the newer other machines that were next to it. And are now dead and gone.
    And to replace the R Fanuc with a new one of the size that will take a part as large and heavy as it will, would hit you ? Probably $200K and that price won't get you another Fanuc that size.
    Everything is built on used machines...lol.......Later Jim
  1. ELOX FANUC
    By gabedrummin in forum Fanuc
    Last Post: 05-07-2009, 02:16 AM
  2. ELOX FANUC
    By gabedrummin in forum EDM Discussion General Topics
    Last Post: 03-16-2009, 05:03 PM
  3. Fanuc/Elox P Series Wire
    By Colin00 in forum Fanuc
    Last Post: 08-17-2008, 02:04 AM
  4. Elox P Series
    By Colin00 in forum Waterjet General Topics
    Last Post: 06-12-2008, 03:18 AM
  5. Fanuc Elox series M wire manual
    By ceandro in forum Fanuc
    Last Post: 01-07-2007, 08:05 PM
