I have a gear cutting machine that has about 30 change gears capable of creating well over one hundred different ratios.
I was wondering if it would be difficult to build an NC controlled gear box?
If I put a rotary encoder on the current input shaft - could a use a gecko or rutex drive to operate the output?
What would be the easiest solution to multiply the input freq - microcontroller, plc, or pc?
If anybody has any hints or ebay solutions on building something like this - I'd appreciate any advice.
Thanks, Dan
