I would like to get an E-stop working. I have a switch that has 2 circuits Reed and Green. 1 is NO The other is NC.
THe bob I use has pin 15 as E-Stop . I have tried different combos and cannot get it to activate. Does anyone know
if I use the Red or Green side of the switch.Do I connect 1 wire to the PIN 15 and the other wire to 5v pin or a ground
pin or a different pin or pins.I have looked at a number of things and they all seem to assume you know where the
wires go. Sorry I don't
Don
