587,874 active members*
3,561 visitors online*
IndustryArena Forum > CAM Software > Mastercam > dynamic area mill?
Results 1 to 5 of 5
    Feb 2010
    18
    dynamic area mill?
    I have this part Im making in mastercam x6. all the main pockets I have already made and left .01" on the walls and floors to come back and change tools for a finish pass.
    how do I pocket JUST the highlighted portion in the picture? If I do a regular pocket it will obviously do the whole area which will waste time, I tried dynamic area mill and its much better but it still mills more then just the highlighted pocket.
    any help would be great. thanks
    Dec 2005
    15
    Re: dynamic area mill?
    Just do a contour. If the tool is too small to take the cut in one pass, take multiple passes.
    Feb 2014
    67
    Use the method I mention in this post... Multiple machining regions --> avoidance region.
    http://www.cnczone.com/forums/master...ontinuous.html
    www.machinisttalk.com
    Feb 2010
    18
    cool thanks, i'll try core roughing and see where I get.
    Feb 2014
    67
    Quote Originally Posted by Etaniyani View Post
    sorry I was meaning to use the selection process to tell the tool where to avoid cutting (the air), stick with the area tool path
  1. dynamic core mill inside to outside
    By Jim Rush in forum Mastercam
    Last Post: 04-08-2012, 07:10 AM
  2. Dynamic mill back feedrate, limit??
    By Ydna in forum Mastercam
    Last Post: 04-21-2011, 05:09 AM
  3. how to mill inside an area and not over an area?
    By jedioliver in forum Visual Mill
    Last Post: 02-22-2007, 06:52 AM
