Originally Posted by
olfoundryman
- a Pogo and a proximity sensor, both located next to each other on the front of the carosel housing and just above the carosel itself, does anyone know what these last two do? And how they should be adjusted?
AFAIK, those sense the lateral position of the arm. The pogo one hits the metal plate on the side of the head, telling the system it's in position for a toolchange.
The other tells it it is full retracted.
When your machine powers up, it should rotate the carousel to check the position of the tool changer. Mine went back and forth, IRC, and I think the arm moved as well.
Chris.
List of parts sources for CNC builders - http://www.CNCsources.net
Dyna Mechtronics 4400C Conversion - CNC bed mill w/toolchanger to Mach3 conversion - http://www.cnczone.com/forums/showthread.php?t=50787
