I am going to replace the switches because the ones that are on the machine run in a Normal Open configuration. That means the 5v only makes contact if the contacts touch.
I want to run mine in a Normal Closed config. That way if a wire breaks or becomes compromised then the loop will be broken and stop the machine.
My tools should be arriving today so I will have lots of work to do putting it all back together as I broke it down to keep the components safe for the move.
AC
AC
Has anyone seen my pillow?
