i need help fixing a problem i'm having in mach3.:tired:
all the DXF files i load are too big for my table or are off set from the x0 & y0.
IE - y-59 x-25 ..
my table is in MM & is setup for x0 & y0, even if i set the X & Y to off set the -59 & -25 my table is not big enouth in the Y
my limits are Y570 & x1460
some are y640 but length is fine.. if i could change the X & Y temp to cut a DXF then set back to normal in Mach3
the other issue i have is a tryed upping the Feed rate & got upto 200 & snapped a 2mm 2flute bit.
I was trying to stop the MDF burning (4.75mm thick) have varied the speed from 3 - max (1 = 8000 max=20000 prm ) mini tool. have also run it at a feed of 30 & still burns. :withstupi
any help out there ???? :stickpoke
