587,434 active members*
3,395 visitors online*
Page 2 of 2 12
Results 21 to 32 of 32
  1. #21
    Dec 2007
    2134
    Re: Dust collector
    Quote Originally Posted by CadRhino View Post
    It is a big mess cutting wood. I have a dust deputy I am going to try. So far my approach has been lots of air ventilation and filtering. I have (2) 300 clear fans that pull air across the back of the tormach and straight outside. I also have a KDS air filter mounted directly above the tormach. With all of that I still get a good layer of fine dust in the shop.
    My only concern is if the dust deputy and shop vac will hold up over time. Some of my wood cuttin ops can be 4-5 hours long (really).
    I routinely do quite large 3D jobs in HDPE and MDF for molds and the jobs can run for 8-12 hours at a time depending on the degree of finish I'm after, creating an unbelievable amount of waste. And if you've ever done HDPE, that stuff creates an even finer and grittier dust than MDF does, and the Dust Deputy handles it all beautifully. The only time I ever get any dust escape, is when the job machines at the outer limits at the front or rear of the machine and the dust boot hangs in space a bit. But even the dust there is limited to a little build up at each end.
    All in all, I couldn't be happier with the DD, it is worth it's weight in gold.
    cheers, Ian
    It's rumoured that everytime someone buys a TB6560 based board, an engineer cries!
  2. #22
    Aug 2013
    980
    Wow, 8-12 hours is a long time to run a dd & shop vac.
    My pieces are Mdf and push the envelope so that may be one reason it is hard to contain the dust.
    Quote Originally Posted by aarggh View Post
    cheers, Ian
  3. #23
    Jun 2014
    1780
    Re: Dust collector
    Quote Originally Posted by MichaelHenry View Post
    Don't forget to clean the motor and fan. Mine got pretty heavily coated with wood dust after just a few dozen parts.
    Right Mike!
    It has been a learning experience thats for sure..
    mike sr
  4. #24
    Dec 2007
    2134
    Re: Dust collector
    It is quite a while, but that's 8-12 hours on one job, and I might run 2 or 3 concurrently so the extractor can stay running for 24 hours or so straight. They're pretty high finish and I generally use a 0.5-1mm diameter ball nose finish pass. Doing HDPE is a breeze though so there's no noise really to annoy the neighbours, and my dust extractor is variable speed so I just dial it down to a bit below 50% and it's as quiet as possible. The steppers actually produce more noise than the spindle or extractor in this mode.
    Another good reason for using a VFD/spindle, they rock!
    Now if only Festool would add a variable speed control to their Systainer extractor model and that then would be ideal for use with a cyclonic unit!
    MDF is particularly nasty stuff, you definitely want good extraction there.
    cheers, Ian
  5. #25
    Sep 2009
    624
    Re: Dust collector
    I'm a little surprised not to have seen any mention of Clearvue Cyclones here.
    Clear Vue Cyclones
    Dust Collection Research - Home
    Anyone doing woodworking should at least glance over the Pentz website. Bill Pentz published very extensively on dust collection with cyclones, mostly focussed on wood shops. His cyclone designs are highly regarded; the problem is that they're very expensive and take a huge amount of space. Apparently the key to success with cyclones for fine dust is very high flow rates, which means big HP fans and everything else. Read his material.
  6. #26
    Dec 2007
    2134
    Re: Dust collector
    Quote Originally Posted by GLCarlson View Post
    Clear Vue Cyclones
    The Clearvue stuff is great but I was lost at the "Finance Available" bit, especially in OZ as the costs were unbelievable. I also spent a lot of time looking at Bill's site before settling on a Dust Deputy years back, but in OZ we have very little choice, and some years back even less. The DD filled a great niche and I'm extremely glad I bought it.
    cheers, Ian
  7. #27
    Sep 2009
    624
    Re: Dust collector
    I boggled at the "finance" line too! Though, compared to other commercial offerings, Clearvue isn't really outrageous (look at a big Grizzly, for example). My boggle meter pretty much pinned when I concluded that the dust collector hp would be at least 3 times the size of my next biggest tool motor....
    And there's some ranting to get through, though one must be sympathetic to Penz's experiences. Still, it's the best single source of information, backed by data, that I've seen.
    Good thing about the Pentz site is that he has drawings, design spreadsheets, etc. One can build a Pentz design (I did- a small one) and it will work well. But- that was before the DD and the Chinese versions were available. Wouldn't build one today.
  8. #28
    Jul 2004
    595
    Re: Dust collector
    Here is one of them from Banggood for $16 and free shipping!
    High Efficiency Cyclone Powder Dust Collector Filter Top Quality For Vacuums IA1 at Banggood
  9. #29
    Dec 2007
    2134
    Re: Dust collector
    Looks pretty identical to my DD but very slightly lesser diameter. Price is pretty damn good though, my DD cost me very considerably more than that!
    When you get the hose, I would strongly recommend to get a flexible one unless the cyclone is fixed into position, I have a very rigid one and it's a pain I find.
    cheers, Ian
  10. #30
    Jun 2014
    1780
    Re: Dust collector
    Quote Originally Posted by David Bord View Post
    I order quite a bit of stuff from Banggood, I missed the cyclone though, I paid 30 dollars for mine and it will be here from mid to late next month from a different supplier-bummer!
    I did get a deal on the 6mm endmills they offer, 1.60 each, and for wood they really work well.
    mike sr
  11. #31
    Sep 2009
    624
    Re: Dust collector
    That's the Mark 1. The Mark 2 has a better ramp for air inlet (or so goes the claim). Still, helluva bargain. For sixteen bucks, put one on each machine.
  12. #32
    Nov 2020
    2
    Re: Dust collector
    My uncle’s workshop has this model I think, and I haven’t noticed anything particularly bad about it. From what he’s told it’s more of a budget option, so it means that it probably has some downsides to justify the price. I have a Grizzly system installed and it works pretty well. The air passes through a metal trash can where the heavier dust is stored. I placed this system outside the shop since I thought there’s no point of putting it in the same room from where the dust is being collected. You can check out some dust collector reviews and see if you spot something better.
Page 2 of 2 12
  1. Router / Dust shoe without vacuum or dust collector / Wind Deflector
    By ajean in forum DIY CNC Router Table Machines
    Last Post: 12-12-2015, 07:42 AM
  2. Dust Collector ?
    By Concepts_Design in forum Tormach Personal CNC Mill
    Last Post: 08-17-2015, 01:01 PM
  3. Dust collector
    By Roctech-Mercy in forum Roctech CNC Routers
    Last Post: 04-22-2015, 04:02 AM
  4. Need a dust collector
    By Dark-Angel in forum Composites, Exotic Metals etc
    Last Post: 11-16-2008, 02:35 PM
  5. Let’s see that’s dust collector
    By automizer in forum DIY CNC Router Table Machines
    Last Post: 03-15-2006, 01:41 PM
