587,801 active members*
3,476 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Dual lead screws and motors on one axis
Results 1 to 2 of 2
    Jan 2012
    0
    I have seen some images of gantry style machines that use dual lead screws to drive the gantry and a stepper motor on each one, I am wondering if I can use my setup this way and if there are any pitfalls of doing this, my stepper setup is from ebay 4 axis set up with 4 290 in/oz stepper motors with a single driver board for my first build. I intend on stepping my my game after the first build. As a mechanical engineer my first build should be a fairly nice one.
    can is use the X,Y,Z axis as normal and also use the "C" as a second X or Y? I will be using Mach3.
    I'll try and include a link to my driver and motor setup below.
    thank you.
    http://vi.ebaydesc.com/ws/eBayISAPI....tor99&caz.html
    35538
    Yes, you should be able to slave the "C" axis to the X or Y without any problems.
    In Mach3, you just set them up as 4 motors, and check a box to slave the C to X or Y.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
  1. Need help with lead screws and motors
    By mullinszoo in forum Benchtop Machines
    Last Post: 11-27-2010, 09:10 PM
  2. Single vs Dual Lead Screws
    By Cold Fusion in forum DIY CNC Router Table Machines
    Last Post: 03-08-2009, 10:26 PM
  3. theory on lead screws/stepper motors etc
    By monkeyturnip in forum Linear and Rotary Motion
    Last Post: 03-06-2008, 02:12 PM
  4. Question about new 4 axis router (lead screws)
    By Tom Kay in forum DIY CNC Router Table Machines
    Last Post: 02-24-2008, 09:03 PM
  5. Dual X axis motors : synchronisation?
    By erlyrisa in forum CNC Machine Related Electronics
    Last Post: 05-25-2007, 11:58 PM
