587,406 active members*
3,351 visitors online*
Results 1 to 2 of 2
    Jan 2009
    8
    Drilling holes
    I have a simple hole pattern that I am cutting in gears, but sheetcam doesn't seem to work very easily with the drawn holes. I have to draw each individual hole exactly the right size in CAD for sheetcam to let me cut it. If i draw a 1/4 hole, it wont let me cut it with a 1/2 bit, and if i draw a 1/2 hole, it won't let me predrill with a 1/4 bit unless i draw another circle inside. I've tried making centerpoints in the CAD, but it doesn't seem to work. please help!!
    Mar 2004
    1806
    Set the min/max hole size in the tool for your drill bit to be inclusive (with a tolerance on either side) to 1/4 or 1/2 min and max and it will work. I do this all the time for exactly the same reason.
    Art
  1. Drilling holes?
    By Cartierusm in forum DIY CNC Router Table Machines
    Last Post: 10-26-2007, 10:16 PM
  2. Drilling holes
    By kentavv in forum MetalWork Discussion
    Last Post: 02-01-2007, 04:38 AM
  3. drilling holes
    By WOODKNACK in forum SheetCam
    Last Post: 12-01-2006, 03:10 AM
  4. drilling 5000 3mm holes
    By barnesy in forum MetalWork Discussion
    Last Post: 08-23-2006, 11:39 AM
