587,202 active members*
3,038 visitors online*
Results 1 to 19 of 19
    Jun 2008
    41
    drill and tap 304 SS
    I'm having a problem with a very simple dill and tap operation. I feel like a dork, but I haven't done and drilling and tapping in stainless since I got this machine so I'm kind of in the dark. So far I've broke a center drill and rounded off a drill. So if someone could take a look at my program and tell me what I'm doing wrong I would appreciate it.
    Oh and my mill is a HAAS TM1
    O7809 (shift plate for guys next door.)
    T1 M06 D01 (#2 CEN DRILL)
    G00 G54 G90 X-1.0 Y1.0
    S1200 M03
    G43 H01
    X.375 Y-.250 Z.1
    M08
    G83 Z-.250 Q.020 R.1 F5.0
    X1.0
    X1.625
    M09
    G80 G00 Z1.0
    T2 M06 (.242 DRILL)
    S1000 M03
    G00 G54 G90 X.375 Y-.250
    G43 H2
    Z.1
    M08
    G83 Z-1.100 Q.025 R0.1 F5.0
    X1.0
    X1.625
    M09
    G80 G00 Z1.0
    T3 M06 (G DRILL FOR 5/16-18)
    S1000 M03
    G43 H3
    Z.1
    M08
    G81 Z-1.050 R.1 F8.0
    X1.0
    X1.625
    M09
    G80 G00 Z1.0
    T4 M06 (5/16-18 TAP)
    S288
    G43 H4 Z.1
    G84 G98 Z-.500 R.100 F16.0
    X1.0
    X1.625
    G80 G00 Z1.0
    G00 X.375
    G84 G98 Z-.850 R.100 F16.0
    X1.0
    X1.625
    G80 G00 Z1.0
    T5 M06 (.500 c-sink)
    S1400 M03
    G43 H5
    Z.1
    M08
    G81 Z-.210 R.1 F20.0
    X1.0
    X1.625
    M09
    G80 G00 Z1.0
    T1 M06
    M05
    M30
    ( .500 thick 2.0 wide 304 stainless, XY0 left upper corner)
    Poor planning on your part doesn't constitute an emergency on my part.
    Aug 2005
    235
    I would cut the RPM on all drilling down about 50% and take much larger pecks. If possible do not peck with 304. T1 = no peck, T2 = 0.250 peck. Pecking and dwelling in 304 is a sure fire way to ruin tools. Peck little or not at all if possible. Flood coolant!!!!
    Dec 2008
    319
    How come you are not countersinking before tapping?
    Jun 2008
    41
    I mostly work in plastics so with plastic I don't. Should I with stainless?
    May 2006
    132
    I'll bite
    I have had the best luck drilling 304 by holding the sfm at 48.
    #2 c'drill rpm looks ok I would probably start at 1000 rpm feed 1 ipm
    use g83. use good quality c'drill
    .242 drill rpm = 757 feedrate start at 1 ipm maybe you can go 1.5 or 2
    peck .03 - .04
    .261 drill rpm = 702 feed start 1-2 ipm peck = .1
    I know guys that can drill faster but I have found that the tools will actually last a while keeping close to these parameters
    use the best cobalt drills you can find use proper coolant mix.
    if you want to try to speed up job then increase feed instead of trying to increase rpm.
    good luck
    Jun 2008
    41
    Thanks for the help guys.
    I'm not to worried about how long it takes, I just need to get the parts done with out killing my tools. I would have ordered some nice tools for the job but it's a last minute deal I took to help some guys out. So, nom I'm under the gun using a HSS c-drill and non coated drills. (nuts)
    So, I need all the help I can get.
    May 2006
    132
    c'drill should be ok.
    decrease rpm about 20 % to start. the feeds should be ok
    just keep the chips coming and dont let the drills turn red and you should be fine. Also please show anyone how we do this or we will have to kill them.
    billy
    Jun 2008
    41
    Well with the hepl from you guys I got 1 good part so far. Here's what the porgram looks like now. What'cha think.
    S400 M03
    G43 H01
    X.375 Y-.250 Z.1
    M08
    G81 Z-.250 R.1 F2.0
    X1.0
    X1.625
    M09
    G80 G00 Z1.0
    T2 M06 (.242 DRILL)
    S400M03
    G43 H2
    Z.250
    M08
    G83 Z-1.100 Q.250 R0.250 F2.0
    X1.0
    X1.625
    M09
    G80 G00 Z1.0
    S400 M03
    G43 H3
    Z.225
    M08
    G81 Z-1.050 R.225 F2.5
    X1.0
    X1.625
    M09
    G80 G00 Z1.0
    S288
    G43 H4 Z.1
    M00
    X1.0
    M00
    X1.625
    M00
    G80 G00 Z.1
    G00 X.375
    G84 G98 Z-.700 R.100 F16.0
    M00
    X1.0
    M00
    X1.625
    M00
    G80 G00 Z.1
    G00 X.375
    M00
    X1.0
    M00
    X1.625
    M00
    G80 G00 Z1.0
    S1400 M03
    G43 H5
    Z.1
    M08
    G81 Z-.180 R.1 F20.0
    X1.0
    X1.625
    M09
    G80 G00 Z1.0
    T1 M06
    M05
    M30
    Dec 2006
    242
    Why center drill, drill .242 and then drill .261? Drill right to .261 Real oil on the tap and the new speeds are much better.
    Jun 2008
    41
    I center dill out of habbit mostly and not wanting the holes to be off. As far as the other I don't think I have the HP to pull a .262 in SS, 1" dp, it's only a TM1.
    Feb 2008
    586
    Sure you do! If you can't cut 1/2" I'd be very surprised/disappointed.
    Jun 2008
    41
    Really..?:devious:I guess I've just been a puss...
    Dec 2006
    242
    That makes no sense. You are pushing a .242" drill just fine right? The difference between .242 and .261 is 8%. Do you have a split point .242 and only a chisel point old style .261"?
    Feb 2005
    376
    I see a lot of things wrong, and these are from my mistakes.
    First, you're driving a #2 center drill .250 deep at .004" per rev, no pecks. Thats a .078 drill point going over 3X deep, no pecks at a HUGE feed for such a small drill. Then on the revision you are up to .005 per rev. Far too much, your original RMP and a 2ipm feed should work ok.
    Second, you are using a center drill, and a little one at that, and driving it half way through the part. Center drills are for putting in centers to use on a lathe. What you are doing is spotting, use a spot drill, or the very tip of a bigger center drill. Since its a quicky job and you may not have the tools, take that little #2 and just stick her in about .030 or .040, not .250, you need a spot, not the grand canyon.
    Third, as has already been said and corrected, pecking a lot DOES NOT make things better. The part is only .5 thick, one shot and done. On the same note, going from a .242 to a .261 drill isn't helping you at all. Drills get really pissy going down a hole that is close to their own size. They jump, chatter, chip, run oversize and do all kinds of nasty stuff. General rule, don't stuff a drill down a hole that is more than 1/3rd the size of the drill. I also think you are banging the feed a little hard, though I'm not an aggressive driller. .0025 to .003 for something in the .250 drill size, I would consider that the transition from ***** footing to aggressive. You have enough chip, but not too much.
    A few more thoughts, if the part is only .5" thick, why are you drilling over an inch deep? Also, already been said, why do you think you can't drive a G drill? But can drive a C drill?
    304 is a big jump from plastic(It's not harder to work with, just different), ease the feed(per rev) back a bit, skip the C drill, smaller spot or a better tool and you should be fine.
    Jun 2008
    41
    Sweet thanks for the advice.
    I made a mistake it's a #3 c-drill. But I'm pickin' up what your putting down. Next time I'll try a spot drill. I agree .250 might have been a bit much and I think it caused the early retirement of the .242 drill. So next time I'll use a spot drill and just pound the .261 in after, correct?
    The part is .500 thick X 2.0'' wide X 2.750 long and I'm drilling and tapping with the part standing on end going into the 2.750, 1.100dp.
    Sorry guys still fairly new with this machine not sure what the capabilities are, Ill take any help I can get. Everything you said so far has made sense and worked really well. I appreciate it.
    Dec 2006
    242
    No spot drill. .261" Screw machine length drill can drill 1.1" and does not walk like a jobber drill. I'd go 400 rpm with cobalt split point drill, flood coolant with preferably soluble oil not synthetic, .004" fpt or 1.6 inches per minute and you'll be done without worn out tools. Need high vanadium tin or ticn coated spiral flute tap and tapmagic or other straight oil for long tap life. I would consider .266" drill to make tapping easier. Tap depths: .300", .500", .700" McMaster.com has nice selection of drills and taps.
    Jun 2008
    41
    Awesome, I'll give it a try.
    So peck or no peck on the drill?
    Aug 2006
    259
    for .5 deep, unless you have problems with the chips not breaking or not releasing from the drill, I wouldn't peck.
    I tend to use a 35/40 SFM on stainless, and on small drills I go about 1 - 2% of the diameter for the chipload per tooth.
    Worst thing with working in stainless is work hardening the material or the tool. Make sure to use plenty of coolant.
    Also, why are you pecking the tap? I would just use some oil and drive it through. I usually run all taps at 100 rpm and oil by hand. unless its a huge production job then I purchase the more expensive coated taps and use coolant.
    And I saw a couple other people say it, but you want to countersink the hole BEFORE tapping. Taps love a nice clean hole to enter, and having the countersink there before tapping will help the tap keep its life, not chip up, and give you a nice lead in thread.
    Just when you thought you had it all figured out, all hell breaks loose..
    Aug 2009
    22
    I realize I'm commenting on an old post, but here is my 2 cents. You've had some good recommendations. Lots of coolant for sure. If you do get the 304 too hot from excessive speed you will work harden the material and NO slowing down will fix that part. You will not be able to go bigger or deeper or cut threads with HSS tooling.
  1. Replies: 47
    Last Post: 02-01-2008, 08:32 PM
  2. anyone have a Fanuc drill mate or robo drill?
    By goodplastics in forum G-Code Programing
    Last Post: 07-22-2007, 04:36 PM
  3. Drill holes with end mill or twist drill ?
    By Argofanatic in forum MetalWork Discussion
    Last Post: 12-30-2006, 05:05 AM
  4. Can I drill AISI 1020 plate steel with a drill bit?
    By Apples in forum MetalWork Discussion
    Last Post: 02-01-2006, 06:15 PM
