587,380 active members*
3,310 visitors online*
Results 1 to 12 of 12
    Oct 2011
    477
    Drag Engraver Love Affair
    I have just completed two orders made from G10/FR4. While these are simple parts, the drawing required that the part number be applied to every one. Additionally, these parts are for an FTA "Buy America" Project and must be distinguished from similar parts that are not made from domestic material. Previous vendors of these parts marked the parts with a Sharpie Pen which not only looks sloppy, the marking is not permanent.
    I decided to mark the parts using the Tormach Drag Engraver. I submitted sample parts to my customer marked this way and they loved them. In fact they like the parts enough to send additional parts my way provided, you guessed it, they were also engraved. As an added bonus the machine can engrave the idenity faster than I can mark the information using the Sharpie Pen.
    I LIKE this tool!!!
    nitewatchman
    Attached Thumbnails Attached Thumbnails 2012-11-03_22-53-39_496 (Medium).jpg   2012-11-03_22-59-09_862 (Medium).jpg   2012-11-03_22-58-50_410 (Medium).jpg   2012-11-03_22-59-21_628 (Medium).jpg
    Sep 2012
    1543
    I've been wanting to get one, have you used it on any metals?
    Jan 2012
    789
    Nice!! I've been tempted, but haven't pulled the trigger yet.
    Feb 2006
    7063
    I'm curious about the fixture in the photos - how are you holding the work piece? What aer the little metal doo-dads in the last two photos?
    Regards,
    Ray L.
    Oct 2011
    477
    Quote Originally Posted by BAMCNC.COM View Post
    Works just as well on Steel although the Heavy Spring is the only one that I use. The spring compression on the G10/FR4 parts is .050" after tip contact. This works well with Aluminum and Brass also. For steel I use .075" to .100".
    The text was generated using the MACH3 Write Wizard. Works but is awkward for me and requires a little manipulation. I usually embed this into the rest of the program and tool change to the Drag Engraver.
    nitewatchman
    Oct 2011
    477
    Quote Originally Posted by HimyKabibble View Post
    Regards,
    Ray L.
    Those are Lithograph Offset Press Plate Clamps. These were used on large offset presses to clamp the lithograph plates to the press bed. They are wonderful! I have a handfull, 20 or 25, and a wrench.
    To use the clamps you determine where the edge of the part is, add 1/16" and drill a 1/2" hole 5/8" deep into the fixture. The clamps have a hinged toe that bears against the wall of the hole and kicker that bears against the other side of the hole. There is a screw in the center that bears against the kicker and forces the clamp over while rotating the top of the clamp down towards the top of the fixture. The clamping force to the side and down is very high. With one clamp in place you cannot tap the part side to side in the fixture without really whacking on it.
    The fixture is made of a piece of scrap G10 and has a 1/4" high stop on the back side that the part is clamped against. There is a 3/4" tooling hole in the center to roll in X-Y Zero and Z zero is on the top of the fixture pocket. The part is 1-1/2" x 3/4" x 3" +/- .005". In this fixture the part is machined on both ends, the top cut to height, center slot is cut and ID is engraved.
    I got these while working in a printing plant as a summer engineering intern in 1971. The Litho Press were being scrapped and there were thousands of these clamps that were thrown away. I wish that I had taken all of them!
    nitewatchman
    Feb 2006
    7063
    Quote Originally Posted by nitewatchman View Post
    nitewatchman
    Could you post a picture of one? I get the general idea, but would love to see how they're actually made.
    Regards,
    Ray L.
    Oct 2011
    477
    Regards,
    Ray L.
    The clamps are commerically called Sterling Toggle Hooks and come in several sizes. The clamps I am using here are #1's.
    nitewatchman
    Attached Thumbnails Attached Thumbnails 2012-11-04_14-30-10_709 (Medium).jpg   2012-11-04_14-30-40_111 (Medium).jpg   2012-11-04_14-31-07_583 (Medium).jpg   2012-11-04_14-35-11_82 (Medium).jpg
    Apr 2006
    439
    I love it Too !
    Here is another ++1 for the drag engraver. I recently used it on a 1911 to put the customers logo on the back of the slide and to do a full "French Border" around the slide. It worked great. Keep in mind that this is hard steel. About 35 Rockwell C. The first one is as engraved right off the machine the rest are after final polish and re-bluing. The customer was very happy.
    Scott
    www.sdmfabricating.com
    Feb 2006
    7063
    nitewatchman
    Those are very cool! Thanks!
    Regards,
    Ray L.
    Aug 2009
    294
    Regards,
    Ray L.
    I agree. I definitely want to get some! In case nobody else searched for it, here they are:
    Toggle Hooks - Sterling Toggle - We manufacture the best toggle hooks on the market
    Feb 2006
    15
    Prices?
    Quote Originally Posted by C*H*U*D View Post
    If you do get some could you let us know the prices please? I tried to find out but they want you to register or create an account. I don't know that I want to do that yet, if I knew the prices I may want to.
    Thanks,
    Jim
  1. Recommendations needed for a drag engraver.
    By TXFred in forum Tormach Personal CNC Mill
    Last Post: 08-17-2014, 04:24 PM
  2. Engraver Machine with Diamond Drag bit to cut mirror?
    By AH11 in forum Engraving Machines
    Last Post: 02-27-2013, 09:16 AM
  3. Spring loaded cnc diamond drag engraver
    By pepperwood in forum Benchtop Machines
    Last Post: 07-14-2012, 01:39 AM
  4. Drag Engraver
    By Regnar in forum Benchtop Machines
    Last Post: 04-22-2011, 07:16 AM
  5. Drag Engraver/Pen holder
    By revwarguy in forum Engraving Machines
    Last Post: 05-18-2009, 05:56 PM
