587,256 active members*
2,823 visitors online*
    Doosan - Puma 240S
    The boss just bought one of these it is a 2008 model anyone have one of these?
    What do you all think of them?
    If anyone has a program using the live tooling and the sub spindle I would really like a copy so I can take a look at it.
    Aug 2011
    48
    Those are pretty cool machines. I'm guessing you don't have a Y axis. Y makes it much easier to mill flats, well at least program them.
    I always had problems finding the space for all of the tools you need to 1 OP a part. Look at MD Tooling for live tool holders. Look at some of the static gang tool holders they have and Doosan offers as well. Anything you can do to simplify the setups will pay off.
    The subspindle partoff can be tricky. There's not much free space to work with.
    I believe it'll use P-codes for each spindle. P11 should be the main turning and c-axis spindle. P12 should be the live tooling spindle motor.
    This is basic advice, but I always setup in 0% rapid. Once I had a good one down we went to 25% for a few more. Then the operator could got to 100%. These machines move quick. You can wreck the crap out of these in a split second and ruin a perfectly good day...
    Here's some simple live tooling action.
    N9(.25" ENDMILL)
    (IN RADIAL HOLDER)
    G54
    M110(INTERFERENCE CHECK OFF - crash detection)
    G0T505
    M35(C-AXIS MILLING MODE ON)
    G0C180.P11(P11=MAIN SPINDLE)
    G97S4200M3P12(P12= LIVE TOOL SPINDLE - UPPER TURRET)
    G0X1.26Z1.
    M8
    Z-.68
    Y-.53
    G1X.82F.006
    Y.66
    X.688
    Y-.66
    G0X1.26Y0
    Z-.3
    C0.
    G1X.85
    Z-.9
    G1X.688
    Z-.68
    Y-.15
    Y.15
    Y0
    Z-.4
    M9
    M5P12
    G28V0P12
    G28U0P12
    G28W0P12
    M111(INTERFERNCE CHECK ON)
    M34(C-AXIS OFF)
    M1
    Thanks RPM any and all info is going to be a great help!
  1. I need doosan puma 300 lathe manual!!!
    By wgpiao in forum Daewoo/Doosan
    Last Post: 02-26-2024, 09:04 AM
  2. Doosan Puma 240MSC
    By dartplayer1 in forum Daewoo/Doosan
    Last Post: 06-07-2012, 06:10 PM
  3. Doosan Puma 2100LY
    By D3abL3 in forum Daewoo/Doosan
    Last Post: 05-19-2012, 12:56 AM
  4. Doosan Puma Programming
    By _WALLACE_ in forum Daewoo/Doosan
    Last Post: 08-07-2011, 12:34 PM
  5. Doosan Puma MX3000S
    By broncranger in forum Daewoo/Doosan
    Last Post: 04-15-2009, 06:51 AM
