Hello everyone,
I'm seriously thinking of building my own milling machine.
i made some research on the web as well as in CNC Zone, but since english is not my language, i may not enter "good enough" keywords or fully understand all of your discussions.
So here what i ended with:
Made to mill aluminium and steel (it would be really a dream if it would be able to handle tool steel, even if i would need to make more thinner passes).
1). DIMENSIONS:
X: 6.5 feet
Y: 3.25 feet
Z: 2 feet
Note: if it has to mill some hard steel (or even mild steel), i dont think it will be done on parts more than 1'*1' big. Big X and Y axis are there for when i need to machine soft materials (clay, softwood, etc). Aluminium would maybe be milled on a 2'*2' basis.
2). FEATURES:
Ballscrews (thought of 1.5" diameter) on all axis.
Linear ball guides.
(For screws and guide, i took that site as an example: http://www.screwtech.cn
NEMA 42 steppers.
10000 RPM 4Kw spindle (BUT speed reduced by belt).
0,0004 inche precision.
Business end not bigger than 7/8 inch.
Speed of machining: the fastest possible, but not especially ligthning fast.
3). ABOUT ME:
I can weld, machine (lathe and milling machine), CAD drawing. I have access to sheet metal brake (up to 1/2 inch thick steel), laser cutting (up to 3/4 inch thick steel), , and cnc milling. The weight of the all machine is not a problem.
In other words, i can build everything I need to reach my goal.
4). MY QUESTION:
Does all that make sense to you? Every comment, suggestion, idea, etc is really welcome. This is not a "one day dream" so i would really appreciate your help. Thank you all, have a good one.
