I have a desktop CNC router that has been working great, but has started to run rough. I don't know what else to call it. It's started to produce inconsistent results, with non-repeatable errors that make the cuts rough and unacceptable. I've tried everything I know how to do to get it running reliably but to no avail. I've tightened everything, lubricated the slides and lead screws, and calibrated the movement on all three axes. I've replaced the driver board. I'm using Mach3 and I've tried running it both directly through the parallel port and with a SmoothStepper. I've replaced and upgraded the software. Nothing works for very long. It will appear to be working correctly and then start failing again. The only thing I haven't done (that I can think of) is to replace the stepper motors.
Do steppers wear out? I've been running them for several years. Is it possible that old steppers could account for the problems I'm having?
I'm desperate! I'm ready to scream and tear my hair out. Could someone please suggest what might be wrong? I would greatly appreciate the help.
Thanks,
Mark
