587,091 active members*
3,102 visitors online*
IndustryArena Forum > MetalWorking Machines > Deckel, Maho, Aciera, Abene Mills > DMU 50 Evo Linear iTNC530 - Setup Program Needed
Results 1 to 4 of 4
    I need a working 5 axis program for testing a DMU 50 Evo Linear with a iTNC530 controller. We are having problems getting our postprocessor working. I'm looking for a sample program (ISO G-Code) with contouring motion. I don't care what CAD system created the test program as long the machine creates the correct part. If I can get the model file, CL file used and the final G-Code output file. I will use this data as a target for correct output of my postprocessor. Any help would be appreciated.
    Cheers,
    Don
    May 2006
    20
    here are 2 files from a swarf made on our Hermle C30 witth TNC530
    I hope this will help you, it are vector lines, not A and C movements
    succes
    Attached Files Attached Files
    http:\\www.adcos.nl
    Mar 2007
    51
    What are the reasons for vector lines? Is that only for the ability to use 3d cutter comp. The only other way I've seen it is
    L X**** Y**** Z**** C**** B**** lines in M128(?) mode.
    In which case I couldn't use cutter comp. Correct?
    why would you want to use iso g codes anyway stick with heidenhain its far better
