587,787 active members*
3,172 visitors online*
IndustryArena Forum > MetalWorking Machines > Dyna Mechtronics > DM 2800 Spindle Control Retrofit
    Nov 2012
    0
    Is there a good replacement for the A-M-C B25A20E-DM1 Servo Amplifier that controls the spindle motor? It appears to be obsolete and having trouble finding something to replace it with.
    Dec 2003
    24220
    There are a few on ebay, usually at all times you will find them there.
    I notice the -AC suffix version is still current at AMC, however, in a pinch you could use one of these as-is, or just remove the powersupply and use as a straight non-powered version.
    There are also alternative models made by Copley-Controls and AeroTech.
    Al.,
    Albert E.
    Nov 2012
    0
    AC conversion to DC
    Hello,
    What's all involved in powering the AC unit with DC? Is there any cheat sheets for doing this?
    I thought I got a BE25A20 on E-bay but the seller isn't shipping or responding, so I may need to convert an AC unit.
    Thanks for your response,
    Mark
  1. Replies: 6
    Last Post: 03-14-2011, 03:58 AM
  2. control retrofit, which one
    By chaz6966 in forum Cincinnati CNC
    Last Post: 11-04-2010, 10:32 PM
  3. Control retrofit Development
    By themil in forum News Announcements
    Last Post: 11-02-2010, 07:29 PM
  4. CNC CONTROL RETROFIT FOR LATHE
    By WIRE CUTTER in forum Controller & Computer Solutions
    Last Post: 10-26-2009, 12:24 AM
  5. SX3 spindle control retrofit?
    By Greolt in forum Syil Products
    Last Post: 02-07-2008, 02:20 PM
