Hi ALL!
Is it possible to build waterjet machine.....? Or maybe it is cheaper to buy one?
Regards Yuriy
Hi ALL!
Regards Yuriy
If you had done a search on CNCzone using 'waterjet cutting' you would have found these two threads plus a lot more.
http://www.cnczone.com/forums/showthread.php?t=16526
http://www.cnczone.com/forums/showthread.php?t=27852
