587,714 active members*
5,039 visitors online*
Page 5 of 5 345
Results 81 to 88 of 88
  1. #81
    Jul 2018
    6492
    Re: DIY UHPC 7 Tonne CNC Bridge Mill
    Hi Sus - The addition of blue metal usually improves the modulus and compressive strength. I expect you would be able to cast in greater thickness then 100mm as your parts are small. You are not casting tonnes in terms of floor slabs and runways etc. But a gravel addition is good in terms of stiffness. Peter
  2. #82
    Sep 2016
    366
    Quote Originally Posted by peteeng View Post
    Thaks Pete. Since I have lab facilities as well, I can get few samples tested.
    Also appreciate if you could take a look at the datasheet https://www.chryso.lk/p/8921/3/5636/en and let me know if you see any issues with this product. This product looks like the closest one I will be able to source locally.
    Sus
  3. #83
    Jul 2018
    6492
    Hi Sus - chrome won't let me look at that link- security issues- so is there another link or publish the data sheet here. Peter
  4. #84
    Sep 2016
    366
    Hi PeteI have attached the data sheet.ThanksSus
  5. #85
    Jul 2018
    6492
    Hi Sus - Thats very encouraging. E47 is very good out of the bag. So if the price is good use E47 and start detailing Peter
    ask them what the typical YM is. The 47 is probably a statistically low value like 2xSD below average or something. They will know the average, say E50.
  6. #86
    Sep 2016
    366
    They said the quoted values are lower than the actuals. For this they are saying more than 55 can be expected.
    The price is very reasonable @0.64USD per Kg. Even without mixing aggregates, the cost for my frame would be low. TDS says upto 70% aggregates is possible. I can get some samples tested with different ratios.
    They confirmed that the grade of the grout is A. Do you think this is OK?
  7. #87
    Jul 2018
    6492
    Hi Sus - Get some and do some tests. Figures look good. Peter
  8. #88
    Jun 2023
    136
    The base has a length of 6.5 meters and a width of 3 meters.
    This is my new product, share it with everyone.
    Attached Thumbnails Attached Thumbnails gantry machining center (2).jpg   gantry machining center (1).jpg
Page 5 of 5 345
  1. How to build a UHPC 4 Ft x 7 Ft CNC Router?
    By rajhlinux in forum CNC "do-it-yourself"
    Last Post: 06-27-2023, 02:39 AM
  2. My DIY Stone Bridge Saw
    By DennisCNC in forum Glass, Plastic and Stone
    Last Post: 07-27-2020, 03:29 PM
  3. DIY H-bridge
    By medved in forum CNC Machine Related Electronics
    Last Post: 06-26-2020, 10:05 AM
  4. Replies: 2
    Last Post: 10-21-2019, 11:21 AM
  5. CNC bridge mill for cutting aluminum.
    By DICKEYBIRD in forum Vertical Mill, Lathe Project Log
    Last Post: 03-05-2017, 03:32 PM
