587,475 active members*
3,653 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Differences from V23 to V24
Results 1 to 7 of 7
Threaded View
    Jun 2010
    104
    So, I upgraded to version 24 some time ago and for the most part I'm happy with the upgrade. The other day I opened a part that I had designed and created on my mill using V23 and upgraded to V24 and simply moved the part to zero from a new point and some other small changes. I regenerated the toolpath and interestingly the tool path on the Z Level Finish, isn't the same? I checked that I was using my post processor from V23 and I am (since I had made changes over time to it).
    Attached is a screen shot of the differences along with the actual V24 drawing. I've double checked everything, even recreated the surfaces and tried to regenerate and the .031 square endmill won't make the same cuts around the lettering.
    Any help will be greatly appreciated.
    Attached Files Attached Files
  1. NM-135 X and Y differences
    By tas99 in forum Novakon
    Last Post: 02-12-2021, 10:17 PM
  2. G98 and G99 differences?
    By cossiegaz in forum G-Code Programing
    Last Post: 05-21-2016, 05:00 PM
  3. Apt and g-code differences?
    By Splint in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-24-2006, 02:10 PM
  4. g-rex 100 101 differences?
    By h_2_o in forum Gecko Drives
    Last Post: 02-28-2006, 07:03 AM
